OK I am also having almost the exact same issues as mentioned by the OP. Although sometimes if I toggle the switch a few times the torch stays on high for a wee while before flickering allot and giving me the low voltage warning. I have had this problem with a 105c and the 1.4A version of the same board (both bought from DX), both in an TF X9.
Batteries are not the issue, LED is not the issue, switch is not the issue… which leaves contact points or electronic components on the board. Cleaning the contacts seems to do nothing so guessing it is not contact.
If I had to guess I would say I have overheated one of the components while soldering the additional AMC7135s… and while if a single AMC7135 was damaged I suspect all I would see is a drop in output and no flickering on high so my guess is I have damaged the ATiny13A.
