Input Voltage:
3V - 9V (1 / 2 x Li-ion)
Output:
4000mA (5000mA (max.))
Mode(s):
6-Mode:
Moon (5mA) > Lo (200mA) > Med (1500mA) > Hi (4000mA)
Double Pressed: Turbo (5000mA)
Triple Pressed: Strobe
Feature(s):
Constant Current
Low Voltage Warning:
When voltage is below 3V, it will keep flashing.
When voltage is below 2.7V, LED will shutdown automatically.
Battery reverse protection
LED short circuit protection
Memory function : ( > 3 secs)
Smart Thermal Management Function
Auto adjust the LED output current to maintain stability and achieves the high performance.
Dimensions:
20mm ( Dia. ) x 1.6mm (Thickness of PCB)
x 7mm (Thickness)(including all component)
Hey Ban any chance you can shrink this driver down to a 17mm or around that size? I will start buying these instead of the BLF drivers if you can. 22mm Fet
There’s a guy, Windforce from Poland, who tests drivers, maybe he’ll get interested in this. But I don’t know why his testing is being ignored so far…. Link
I think a reversible connector is a lot more convenient than Micro-USB. I'm also pleased with the other functionality added by the USB-C standard, even if not everyone manages to implement it properly.
Pretty sure what Bangbad is selling is nowhere close to what BanL does.
The SST-40 emitter is yet to be manufactured in high CRI.
3600 lumen out of a single SST-40? Not before it blows up. False advertising.
What the @#$%? The SST-40 is not a multi-die emitter.
I was going to show that photograph where two different emitters are shown, but these @#$%%$#@@#$ embedded the image in a different page nested inside the main one.
I think the specs are wrong because look at the pic that is here the LED is clearly a XHP50.2? Its a mix up of specs and pics id say. If you scroll the pics on Banggood site its got a SST40 pic and also a XHP50.2 next to it.
Ah i just read you wrote this for some reason your writing is small.
BanL, now that you sell 3030 mcpcb, do you think you will stock some CSLNM1.TG, CSLPM1.TG, CULNM1.TG and the Oslon Square 92 or 96CRI emitters? If you can source the Oslon Square, please get below the BBL tint bins. Thanks.
