Today I got the brand new KDIY KF8 in. I bought the 5000K version, with Cree XHP50.2 J4 3A led. This is a 100% Kaidomain developed new flashlight, using a (as far as I can know) new design flashlight body edit: I'm wrong here, texas shooter pointed out that this flashlight is an unbranded Roche F8, it has KD's 20mm XM DTP-board and their H1-A 20mm boost driver. The cost is a moderate (IMO) 34 dollar shipped. I had been looking for a good compact host to use this driver and the XHP50.2, but then KD came up with this light that is exactly what I wanted to build. And I think that the design is really handsome! The design seems inspired on the Thorfire VG10 which I think is well looking too, but it is slightly larger with more fins, and I like it better because of the flat bezel:
If you open it up, the used components seems good quality, although the switch assembly is not ideal with all non-soldered contact points, the switch is a small Omten. The lens is AR-coated. It is a no-pill design. I started improvement by soldering brass cup-spring-switch contact plate together (with a bypass).
The ledwires are impressively long
They are 24AWG, I shortened them by two-third.
Some performance.
I did some resistance reductions but that did not alter the performance, it will probably hold performance a bit longer upon draining of the battery but the driver nicely maintains a constant current.
The HA-1 driver has been discussed before on BLF, it is a single li-ion 3A (to the led) boost driver for 6V leds, has 4 nicely spaced modes with a good useful low (10 lumen) - med1 (250lm) - med2 (770lm) - high (1930lm). (own measurements on this flashlight)
What is great about this light is that it maintains the high output very very well, I did a 10 minute test-run on high on a 30Q battery without cooling: 1930 lumen at 30 seconds, 1830 lumen at 5 minutes, and still 1780 lumen at 10 minutes, that is 92% of the start-output
. The head temperature was 72 degC by then (measured with an infrared thermometer on the fins), feeling hot but it is still a very safe operating temperature.
The battery current upon start with a fresh battery is 4.6A. after the 10 minute test run and after cooling down, the battery current was 4.95A , the driver copes with the lowered battery voltage by increasing the current, like a boost driver should. With the partly drained battery and cooled down flashlight I measured 1910 lumen output at 30 seconds, so this light really does compensate the battery drain well.
I did not measure led-current but based on my XHP50.2 output test, on high this should be about 2.7A, close to the specs of this driver. This current allows me to calculate system performance too, it calculates at 108 lumen/watt. For a flashlight close to 2000 lumen this is great, better than any other flashlight of this output that I have.
The beam shows a good even illuminated large white hotspot (as expected for a large led in a compact reflector), a yellow-ish corona (as we got used to with the new Cree leds) and bright spill. A semi-flooder. I may do a beamshot tonight but there's no surprises there, it is as good as you can get with the XHP50.2 I think.
Edit: here's a white wall shot at 2.5 meter (underexposed to show the hotspot well):
Conclusion: Kaidomain, this light is a winner!, it looks good, almost everything is very well done (except the switch assembly and long thin ledwires, but it still works alright so what do I complain?), the performance is good and stays good during longer use, and it is suitable for modding.
Edit: some extra bits of information in posts 20 and 21.
Disclaimer: bought this light from my own money, no affiliations with Kaidomain.
