I recently received my Keeppower 26650 batteries and immediately did Normal Test on Lii-500 but the results were much lower than the rated spec… is the below result normal or I got fake KP batteries?
I believe the Lii-500 stops at 2.8v but based on my observation when I did the tests, I doubt if 2.8v to 2.5v will yield more than 100mAh. Thanks for the input though…
Anyone would like to share their x capacity from y brand? Just curious how under capacity my KP’s are…
Hmm I have the idea the Liitokalas show a rather high mAh so when it gives you such a low value I would worry too.
How do the cells look and what do they weigh?
Was hoping it was only the Lii-500 that’s misreading the capacity but the result was very close if the same on my other Lii-500 charger.
Weighed the batts and got this
KP 26650 5200mAh Protected: 96.1g
KP 26650 5200mAh IMR: 88.5g
Cycle them 2-3 more times sometimes they need to be woken up a little bit even though they say lithium doesn’t need it. I’ve found that some cells do need to be cycled and go up in capacity. Sometimes a couple hundred mah. I use a opus to run my test on. But have seen on multiple cells lithium and nihm the 3rd-4th cycle is the highest the cell will test
Edit
I will say the 5200 mah evvas from mtn are spot on. Those are available non or protected The thorfire 26650 were spot on and the liito Kala 50A all tested above rated capacity down to 2.8
I exchanged my Opus 2.2 and got another one. I guess I got lucky because my second one is much more accurate. I tested 4 x 30Q FT and 4 X 30Q BT and the FT were 1.5% higher than HKJ’S number @1amp and the BT was only 0.9% higher than HKJ.
The others I have tested are also much better than the one I exchanged!
If your interested you can see the results in the thread below. I do not feel like posting all the pics and data again!
Thank you, I checked that out…. good info too. :THUMBS-UP:
I think you posted some of it HERE too before a certain person showed up…….
Very good info. Maybe…. …. they fixed it. ???
My first one was in that 5% to 10% off range with a few exceptions that were very close.
I do not think Opus fixed anything because this is the same model.I guess I just got a more consistent one. Every test I did/redid was closer to specs and HJK than my original one.
The BT-C3100 inaccuracy is possibly impacted by its power supply's inability to keep the input voltage completely stable. If you go check HKJ's reviews of it (3 available: v1, v2.0 & v2.1) you'll find references to this issue. It's a botchy PWM design which would probably work better with a 10A supply, imho.
