Hmm, I thought they moded the light and changed the emitter.
Might have to ask there or read more, though the translation… I don’t speak German either. The pictures showed up to me only after I registered there.
I think it was a swap. And that the XM-L U2 mark on the board is just on the board and the emitter is actually T6 and not an U2.
He did a “dedome”, removed the dome from the emitter itself, you know, the protective “translucent” dome that covers it. And fitted an KD driver 8*7135 2.8A.
Nice pics. Puzzling, though, M10a is less brighter/thrower than M10 despite deeper reflector and possibly with U2. That 7T6 impressively swamps both M10 and M10a. Hope the German page posts some more and clarify these. Thanks again for the links.
It’s all about the XM-L bin used and the driver that feeds it the Amps.
M10a seems tighter yes and also hes this soft spill ring, where as M10 seems like the cree is too far and there is no soft spill ring.
Yes, M10a came with a board that had U2 printed on it, but probably is just T6 from what I read around there.
M10 came with T6 that he swapped for U3 at home.
I could guess that from the German text too, it translates the same.
The thing with 7T6 is it’s not at all comparable to the M10 0:)
Great… tried to ask there and I can’t even see my post, hopefully they won’t filter it out or at least will translate it for me XD
With the reflector pictures you have to keep in mind that the M10 is already moded.
It has U3 vs the probable T6 in M10a, and also the drivers give different Amperage, higher for the M10 with U3.
Tried to ask there if he could do a beamshot with one light and only swap the reflectors.
Hopefully he also knows how to set up the camera and not use the automatic mode.
Then the brightness will be useless anyway.
All in all can’t help but feel that the differences between M10 and M10a are minor. Still my preference is M10a for deeper reflector and the soft spill ring. Thanks for following up.
Same here, plus it depends on the seller if they can even tell the difference XD
Already read somewhere that they received M10 instead of M10a.
I’m now a happy camper waiting for my M10a to arrive.
And some other bits like an AVR programmer, 105c driver, ML-102, 26650 TrustFire 5000(4200)mAh. Total of $45, not bad for a light, 2x battery, charger, custom driver with a programmer for it :bigsmile:
This light is no longer the excellent quality it used to be, here are my list of shortcomings
-the glow in the dark boot has splotches of glow
-the pill is made from some metal i can just cut with an exacto knife, and would be nice if it were a bit thicker
-the driver spring fell off after 2 days (i’m replacing it anyways)
-the glass has the small chip in the corner
-the star is glued on, and has dirt all over the top of the pill, the LED is dirty and slightly scratched as well
-the light overall has a cheap feel, the anodizing aint bad but its not great either.
