What is the diameter of the LED Board?
Can you get more power from the driver? [Resistor]
Hi treadneedle, do you know dimension of reflector and any photos of reflector? thanks.
Hi Cembar, yea sure thing. Gimme an hour or so to do this for you.
I can´t give you the exact measurements since the head is glued and I can´t take out the reflector but using a standard ruler I can measure a diameter of 3.5 (maybe 3.6 centimeters and a depth of 3.8-4 cm from the outside.
Hope this helps,
K.
hmm, it is not changeable?
thanks
I’ve measured this super quickly as I have to rush out.
OOO, thanks threadneedle. is it difficult to move outside?
My pleasure. No it’s not difficult at all. It’s threaded so it’s just a matter of unscrewing it.
Thanks Threadneedle, I will buy it from ebay and I will change it’s reflector with SMO.
No worries, Cembar. I’d recommend buying it from Banggood or Gearbest and using a code from M4DM4X or Freeme. It’ll be a substantial saving.
Is there a SMO reflector for it available?
Bob
I will search, maybe C8 SMO reflector.
How much mm emitter hole?
It looks maybe 0.75mm wider than the diameter of the LED dome.
Thank you very much Threadneedle.
Could you share photo, without reflector top area photo?
very bad torch :laughing:
On the contrary, in my opinion! It’s a fantastic MT-G2 torch for the price. I managed to damage the LED through my own ineptitude
