The King of Tactical Lights 2017
One-Touch Strobe, compact rechargeable tactical flashlight XT2CR is released today.
CREE XHP35 HD LED/1600Lumens
Extremely compact but intensely bright, XT2CR delivers 1600Lumens high output and illumination up to 240meters due to the integration of CREE XHP35 HD LED and Klarus High Efficiency Circuit.
Compact Size/Dual-Switch
Weight of 88.5g(w/o battery), size at 139x25.6x25.4mm for the perfect size, dual-switch tactical tail cap design with a primary switch with momentary on, on/off and constant-on functions, and a MODE switch with one-touch strobe and one-touch low functions, XT2CR is very comfortable for one-hand operation, easy & fast for one-touch access and accurate tactile switching.
Extremely Compact/Multifunction
Though extremely compact, the mini rechargeable tactical flashlight XT2CR is designed with multiple functions, include One-Touch Strobe, One-Touch Turbo, one-touch low, SOS, Intelligent Temperature Protection System, Intelligent Battery Load Check System, Battery Capacity Indication, fast USB charging, quick mode change, constant current, compatible with multiple batteries, etc.
Programmable/Dual Settings
XT2CR is programmable with dual settings. When under tactical setting, the one-touch strobe feature can disorient dangers quickly, one-touch turbo feature can help illuminate distance clearly. And when under outdoor setting, one-touch low feature delivers soft light that protects eyesight when reading, one-touch turbo and SOS features aid in rescue efforts when in dangerous environments.
Rechargeable/Micro-USB Port
XT2CR is rechargeable, it is designed with a Micro-USB port for fast charging via wall outlet, car charger, PC/Laptop, or powerbank. The charging port has three-tier protection, reliably guard against moisture, dust and sand.
Digital Intelligent Charging Module/Intelligent Battery Copacity Indicator
The mini rechargeable tactical flashlight XT2CR is integrated with a digital intelligent charging module with real-time monitoring of charging status, prevents overcharging, charging current up to 1A, safe and fast. With an intelligent battery capacity indicator to show battery status, it will be easy for to know: Red for charging, Green for fully charged, and Flashing Yellow indicator for inspection required. And you will be aware of light status by checking the state of battery charge at anytime. Green means battery capacity over 70, Orange means battery capacity 30–70, Red means battery capacity less than 30, but if Red and flashing, it means battery capacity less than 10% and requires immediate replacement.
ITS (Intelligent Temperature Protection System)
The mini rechargeable tactical flashlight XT2CR also utilizes Klarus ITS (Intelligent Temperature Protection System) to monitor internal temperature and adjust output of maximum brightness, protects LED and internal components to ensure safety, stability, optimum performance and user comfort.
Same with Klarus Searchlight G35, Programmable Tactical Light XT11GT and Magnetic-charging Tactical Flashlight XT12GT, XT2CR is the fourth Klarus light that incorporates with the intelligent battery load check system. With high-performance 3600mAh 18650 battery included( featured in TESLA electric cars) to deliver 1600lumens, XT2CR also has broader battery type compatibility with greater protection for batteries, it is compatible with all types of 18650 Li-ion batteries and CR123A batteries.
Designed for Safety/Multi-Tier Protection
Designed for safety, the mini rechargeable tactical flashlight XT2CR has multi-tier protection. It has reverse polarity protection to prevent circuit damage from incorrect battery orientation, front and rear internally mounted springs to protect against shocks and drops.
Extremely Waterproof/Ease of Mind in Any Weather
The mini rechargeable tactical flashlight XT2CR is extremely waterproof, waterproof level is IPX8, it can be put in water and down to 2meters and suitable to use in even the most severe weather conditions, you’ll have ease of mind in any weather with this light by your side.
Ingenuity in Craft/Ergonomic
Crafted with ingenuity, XT2CR is an ergonomic tactical light even from the design stage.
6061 Aerospace Aluminum alloy construction, mil-spec HAIII anodizing; Durable stainless steel strike bezel, shock and abrasion resistance, can be used as a defensive tool in emergency; Patented dual-switch tail cap, easy to operate; Stainless steel clip, easy to carry; Grooved texture design, comfortable and slip-proof.
Multiple Applications
XT2CR can be used in various ways, it can be used for law enforcement, search and rescue, hiking, cycling, camping, expedition, self-defense, SOS, etc.
4 Lighting Levels/2 Flash Modes
The mini rechargeable tactical flashlight XT2CR has 4 lighting levels and 2 flash modes according to the ANSI data.
Extreme high mode at 1600lumens with runtime for 1.2hr, high mode at 400lumens with runtime for 4hrs, medium mode at 100lumens with runtime for 14hrs, low mode at 10lumens with runtime for 200hrs, strobe mode at 1600lumens with runtime for 2.4hrs, and SOS at 100lumens with runtime for 42hrs.
Parameters for Klarus XT2CR
Parameters for XT2CR:
• Input: 2.5V-8.4V
• Battery: CR123Ax2; 18650 battery(protected)x1
• Charging: 4hrs (1A, 3600mAh)
• Reflector: Mirror-polished
• Switch: Dual-Switch Tail Cap
• Size: Head (26.5mm /1.04”) x Body (25.4mm/1”) x Length (139mm/5.47”)
• Weight: 88.5g (w/o battery)
• Material: 6061-T6 Aluminum alloy
• Waterproof: IPX-8, waterproof down to 2 meters
• Lens: Hardened, AR-coated lens, scratch-resistant
Package for XT2CR
Standard package of Klarus XT2CR:
1x XT2CR
1x 18GT-36 18650battery
1x Holster
1x Layard
1x O Ring
1x Micro-USB cable
Optional Accessories:
Rail Mount
Charger
TRS1 Remote Switch
The King Light of 2017 is coming SOON—-Klarus XT2CR.
Now, can you guess what’s the differences Between XT2CR and the mini size tactical light XT2C???
More about XT2C: Home - KLARUS Lighting Technology Co.,Ltd
New Product Release: Penlight P20
Klarus High CRI Diffused Penlight P20 is an extremely lightweight, 230 lumens compact pocket light that developed for multiple tasks for medical examination, repairs and inspections, daily use, everyday carry and outdoor, it is specially designed for doctors, engineers, professionals, sportsman, office EDC, outdoor trips.
The features of this pocket light are compact durable construction, exquisite design, nichia high CRI LED CRI≥90(5000K), zero blue ray damage to the eyes, high performance PMMA optical lens with 92% light transmission, light can be projected evenly on exam area, optimum beam output, mode memory function, and a user-friendly tailcap switch for single-handed operation. Complete control with one-touch on/one touch off/one-touch mode switch from the tail switch, convenient and easy to operate.
Penlight P20 is excellent as either a stylus light or as a pocket flashlight, and also a reliable backup light. The P20 Penlight works with 2 AAA Alkaline or Ni-MH batteries and has a runtime up to 193 hours with High-Medium-Low output mode.
Features for Klarus Penlight P20:
• Nichia 219C LED, max output up to 230 lumens, max runtime up to 193 hours.
• High CRI (color rendering index) LED, CRI 90, (5000K), simulate natural lighting.
• 2 AAA batteries, easy to power.
• PMMA optical lens, 92% light transmission.
• Professional lens system design, soft even spot without dark area to avoid mistakes in exams.
• Zero blue ray damage (RG0) to the eyes, perfectly suited for pupil examination.
• Streamlined pen design, lightweight, stylish, easy to carry.
• Stainless steel clip on aluminum flashlight tube with excellent grip texture.
• Mode Memery, the last mode will be automatically entered into when turning on after 3 seconds of powering off.
• Reverse polarity protection to prevent circuit damage from reversed battery insertion.
• Aerospace Aluminum alloy body and Mil-spec hard anodizing(HA III); abrasion resistant, lightweight and robust.
•Stainless steel bezel design protects the lens and reflector system from drops and impacts.
New Product Release: FT12 Filters for XT12GT
Dear XT12GT Flashaholics,
How long time you’ve been wishing to own a Red, Green or Blue Filters when hunting, hiking, fishing, crossing in foggy area?
No need to wait any more, here comes your helper ===>>> the FT12 Filters
FT12 Filters for the Klarus rechargeable tactical flashlight XT12GT(Bezel around 45mm) are developed and designed to extend the opportunities of flashlight usage and make your devices multifunctional and more efficient. You will get a wider beam that covers large area and provides perfect light for camping lighting and indoor usage with these diffusers. With such filters, the flashlights will be better suitable for close actions, reading, items search etc. Color filters are mainly used in tactical lighting.
The Red Filter has a larger number of applications. Used for emergencies, caution and hunting to not spook game, great for penetrating fog or smoke. Some animals can’t see red light so it’s good for night hunting and is good for map reading because it doesn’t disturb night vision. Flashlights with red filters are also widely used for signage.
The Green Filter is suitable for hunting, hiking and tactical use as a beam of green light can’t be seen from aside and doesn’t disturb a game. Green light is also very popular for night time map reading and covert operations because it does not disrupt night vision.
The Blue Filter is widely used for night fishing, tracking wounded game, and close reading as well as navigation devices. Blue light is also perfect for reading chart and maps.
Besides compatible with Klarus rechargeable tactical light XT12GT, F12 Filters also compatible with bezels size around 45mm.
