KR1AA beam is looking good
The earliest production FW3As had no retaining rings at all. The driver was press-fit into place. The tailcap guts would fall out if you changed the battery at the tail.
Without the retaining rings they actually had fewer issues with switch contact. Sometimes the problem with retaining rings in this kind of light isn’t that they’re too loose, rather it’s they are too tight. They work better with the retaining rings removed completely, or loosened so the boards on either end of the inner tube can float and achieve optimum contact.
