Kung Pao Nichia (Pic heavy)
We used to be able to look at the stars, enjoy a moonless night. Now a cop lives next door and has lights on outside 24/7/365… he bough my sis’s house. If he didn’t have camera’s up I’d douse the hot lights with ice water….
Review: Fitorch ER16 (pic heavy)
I received this light through the "GEARBEST 2018 Mid-Year Giveaway". I have a few details to fill in below. I'll update them once I have them..
Pros:
  • Bright little light with a useful general purpose beam profile
    • Good balance of throw and flood.
  • Good looking light with very nice flat black finish
  • Well-executed machining with square-cut threads. Arrived properly lubricated.
  • Attractive reflector and A/R lens.
  • Good mode separation
    • Measured 90lm (L), , 340lm (M), 1200lm (H). Moon was too low to register in my integrated tube. 3lm spec looks about in real life.
  • Well-machined, thick Retainer rings for both the Driver
  • Tail stands well
    • Has passages to prevent lanyard from interfering with tail standing.
  • Nice deep-carry pocket clip
  • Strong Tail Magnet. Holds light well in all positions.
  • UI has lots of great features such as voltage feedback via the switch, lockout functionality, hidden but rapidly accessible strobe mode.
  • No detectable PWM or whining sounds
Cons:
  • High output to low output mode order
    • This is mitigated somewhat with last-mode memory
  • Anodized finish tends to scratch off against metal hard edges.
Built-in Charger:
Charges at .__ amp rate and terminates at 4.1__ (will provide this later). Didn't test for proper charging algorithm.
Output:
I recently made some changes to my integrating tube and have not had a chance to calibrate yet. So take my measurements with a grain of salt. Using an INR18650-20R (all my 18350's are a bit tired), I measured "tailcap" amps of 3.7 at start up. The amperage drifted to 3.6 amps at about 30 seconds. Lumens measured 1200-1300 at startup and drifted down to about 1100-1200 at 30 seconds. I saw not indications of thermal sag.
Throw measured at __kcd.
Driver and Testing Results:
The manual says the head is sealed. There is white glue holding the driver in place and the bezel wouldn't unscrew by hand. Normally, I like to open up a light so that I can measure both input and output. At this moment, I don't have time to break open the head and test. I also really like the light and don't want to risk hurting it at this time too. I connected the driver input to a variable cv/cc power supply and got some weird results. Amperage draws very low and the switch slowly led flashed red during the process. Like with cells, power consumption dropped as voltage dropped.
The light appears to be some type of direct drive type driver. I could not detect any PWM (visually or with phone camera). Also could not hear any whining. Due to the power supply issue, I didn't test low voltage protection.
UI:
Excluding the high output to low output mode order, the UI is great. The last mode memory makes the mode order tolerable, but it would be much perfumed to have low to high order.
Some Photos:
The product box is very attractive and which contributes to making this a great gift light. The packing in the box protects the contents well.
Battery tube and tailcap are one piece. Driver is held in place by a white glue.
Square-cut threads also on the top end of the battery tube.
Nice looking reflector and A/R coated lens.
USB port cover is nice and snug.
Beam Shots
High, Medium, Low, Moon modes:
Another part of driveway with same mode order:
I tried a slightly different camera setting for this closer range shot. Pictures seem darker than reality. Sorry for the blur on the high mode pic.
Conclusion:
This light is very nice. All kinds of nifty features all in one package. I tend to just EDC triple A lights, but I light tempts me to give it a shot. Wish is was winter. It's a winner all the way around.
nice SRK/Nichia 219 mod :slight_smile: its probally the best-tint SRK out there.
Nichia should build an XM-L sized, or a MT-G2 sized version of the 219B emitter…
Thanks DBSAR. That would be fantastic. One can only hope they have something like that in the pipeline.
I have implemented your tail cap lockout mod in almost all my SRK-type lights. It's still one of the lowest cost, easiest, reliable mods that I know of.
Spicy, if not the kung pow nichia, call it the “Sriracha stunner” because “it’s hawt!” :smiley:
Good to hear the tail cap mod works well for you. :slight_smile:
I have did that mod for a fiew of my own lights since the first one on the FF Rook.
That stuff is awesome. Gotta respect it though big time or it will kick your A. The roster graphic says it all to me.
Sweet mod! I like it! :)
Thank you Racer. I was getting close to PM'ing you because I hadn't seen you around here much lately.
Love the build. I seriously would not change anything in this light. It is super nicely done.
Im still around, just haven't been modding or posting that much lately. For the first time in a year I dont have a single order incoming. Maybe im cured. :p Ill order some more stuff soon though, but probably not many flashlights. I still have several projects/lights that have been sitting and waiting for me to mod them, but im in no rush. Im noticing there are less and less interesting lights to buy (that I don't own or have owned). And its not much new stuff to try out in terms of emitters either, so not that much new stuff to experience. I think your mod, the emitters you used and peoples experiences with FET mods are quite interesting though. :)
Oh no! We've lost you to the vaping crowd too!!! (Just kidding.) Good to see you around Racer86!
-Garry
Im reading BLF on a daily basis, if not from the computer then from my cellphone. I still need my fix and I always have plans for mods to do. ;) Im just down to a more sane level now.. :D
Moi vaping? I haven't completely lost it... :p
Yeah, I find that I at least read BLF even when my interest in lights wanes. Lately, I have been interested in doing mods, even though there are a lot of other things I should be working on this time of year. I'm some what neglecting them as I try to finish a few lights and then move on to the scratch build contest.
I think this will be a long term hobby for me as technology should keep improving. All this driver activity is exciting right now.
Ledsmoke,
Thank you very much for the nice compliment. Other than output on high (which is more than enough most of the time since I mostly use low and medium modes), I really have been digging the light. I just love having the option to belt out a bunch of light. Just in case it is needed (OK, wanted).
