Been shifting this one to the back burner for ever. Decided to finally finish last night. At 7:30AM this morning, I finally finished. Some mouse overs below.
Used these awesome emitters:
Reflowed on to Noctigons', which were reflowed onto two .035" copper disks made from this copper. Modded the driver Comfychair style. DrJones MiniMo Firmware. Modes 0, 1, 3, 9, 45, 125, 255.
Stock pill was a ridiculus thin, loose-threaded affair and I wanted 3 amps per emitter. So drilled out threads with a 1 3/4" circle cutter and then ground out to fit a disk cut from a 2" circle cutter.
Pressed in using a 1 1/4" socket (1 3/8" wouid have been better, but I could not find it). Here it is in position to press. Mouse over is after pressing in. I should have filed the disk to a slightly narrower diameter. Ended up needing to use a 12 ton press and it deformed the disk slightly. Had to spend a bunch of time lapping it flat.
To enhance heat transfer up head and into the reflector, I lined head wall around pill with .021" copper that I got from Dchomak. Mouse over shows were it makes contact with the reflector. Actually goes up a bit higher because reflector was not tightened down into position.
Copper braid and tape for tail board.
Tail cap lock out DenBarrettSAR style. Sanded off anno before he invented that mod. If I could go back in time, I would have not sanded the anno off the inside lip. Just the flat contact surface. Blurry mouse over is plastic disk (Cut from bottle top) for smooth tail cap spin and to press tail board against tube body when light is in use.
Conclusion:
Absolutely love the light. The small emitters increase throw and the CRI and tint is fantastic.
Don't know the current to emitter or tail current yet. When testing with one old Sanyo lap top pull I was getting 5 amps. If driver behaves like Comfy's, it should put out 12 amps. I will measure tail current soon and report.
Below is a daytime wall shot. The whole beam is not in picture, but the spill isn't visible anyway. You can see one of the emitters is not centered. Wall is tan colored.
These 2 photos seem a little brighter than reality. Usually, its the other way around with my camera.
PS: The domes tear off (and not in a good way. Phosphor partially sticks to it.) way too easy. I lost 3 emitters building this light. I didn' even touch the domes. I was drilling the copper cross spacers out. The vibration made the emitter domes break off. Maybe I subjected them to too much heat when reflowing.
(with a disposable XM-L, NOT those nice Nichias!)
