Hi all ,it was suggested I build a triple. ( scroll through for other builds)
so here we go ,inspired by the blf 26650 pocket light thread.
so I have on order 3x 36.5mm triple reflectors,3 x 37mm lenses
9 x 16mm stars with xpg3 chips.
2 x 105e 16 extra chips 1 blf x6 driver.
various orings
A start to 3 x different tail caps
due to photobucket issues I will just post some finished pics
I have no idea what your building. Is it three triples? Looking forward to the continuation of your build ltp. As usual I have no doubt this will be different. :+1:
Very cool design and machine work, enjoying the build! :+1: Triple and Quads with the optics are O.K. but I’d rather have triple reflectors in a small package like these! Where did you find these small triple reflectors?
around 65m to shed. Looks like some debris on the phone lens.
I guess around 2k lumens for 3 xpg3 at 6a , doesn’t take long to warm up.
happy with the beam pattern…
It happens. I’m no expert but some do and some dont. A crook earth also wont help. If I get a chance I’ll drop in and you can give me a lesson on soldering chips.
Just a little update
2 more heads built slightly heavier diameter up to 41.5mm from 40mm
head is now 8mm longer shelf now 10mm thick and another 3mm of thread
in the driver battery tube area
bit to do yet and i’m adding a quad to the mix/
series.so it will be 3x3+ a 4 all jammed into a 42mm dia head.
will have to trim the reflector a tad and perhaps tighten the thread pitch
and then we may see how good the blf drivers from bangood are…
slightly bigger than the first one
the blf driver is doing some strange things when trying to take a tailcap reading it flickers and goes back to low instead of the 4th mode
but works fine with the cap fitted,
