This is a one of a kind light. No others were made exactly like it. It’s the only one with the combination of the warm SST-90 LED and the stock switch function. I’m a warm nut and I wanted to preserve some of the stock water proofing so I didn’t opt for the varapower controller. This includes the UCL lens, the aspheric lens and spacer kit, spacer tube to accept C cells, 4 x Tenergy Premium 5000 mAh NiMHs and the “stock” mag head so you can make it look like a sleeper Mag if you want. Here’s the link to Kevin’s build page if you want to see what went into this light. It’s a BEAST of a thrower, especially with the aspheric lens. This light/cells have a total of 10 minutes of run time. The cells have also been conditioned a couple times in a charger to maximize the current that can be drawn from them. As you can see in the photo, the paint/coating on the bottom ring of the turbo head has some wear from rolling around on the table. The rest of the light is in great condition.
http://flashlightnews.net/forum/index.php?topic=2789.0
Where’s the photo?
Not seeing the link or the photo(s).
bump
BUMP WITH LOWER PRICE
