I quit buying ICR18650s. Follow a few simple rules.
Use cells from packs less than 3 years old.
Identify cells and their capacity. Stick with Panasonic, Sanyo, Samsung, Sony, etc….quality cells.
Check voltage of individual cells. Discard any that read below 3.2v.
Use a hobby charger to determine capacity. Discard any cells that are less than 80% capacity. Label capacity. Discard any cells that gets extremely warm or hotter than usual. This applies to ANY LI-ION cell regardless of source or protection circuit.
For multiple cell flashlights use matched cells from the same pack with same capacity.
Disclaimer: If you are uncertain about anything written above then don’t. YMMV
Eh, I’ve done a bunch of pack pulls, maybe 5? 4 Panasonic (IBM Thinkpads) and a Sony pack. Accidentally shorted 2 batteries with shears (sparks flew!), but tossed those out, the rest were all fine.
pretty much what willie said. If you’re careful with charging the cells after each use and not running them all the way down, them being unprotected isn’t a big deal. If you’re really worried about it you can get single cell PCBs from DX for $1-2, although you’d have to check to make sure the over current trip level is high enough.
I’ve done quite a lot of laptop battery packs (including Macbook pros :laughing: and it’s just the luck of the draw what you get. Of the 2 most recent packs (in the recycling bucket, woohoo!), 1 was completely toast with none of the cells holding more than 500mAh and the 2nd was awesome, with just one duff pair (0V) and 2 pairs that yielded between 1800 and 2000mAh. One of them is now in a rear bike light and the other 2 or 3 are about to go into a camping light
I personally wouldn't use unprotected cells in multiple set ups ..i'ma big fan of unprotected cells and have ripped open about 10 laptop battery packs.Snce i don't have a hobby charger to fully test batteries for me it's sort of seat of the pants ..I recharge and have had good success with cells under 3 volts ...more than I would have thought ..i also have had very good luck with very old battery packs too .the only real tests I use is how much a battery drops after being charged up and left sitting and how well they handle a pretty serious draw against them ...A littl bit subjective but when mixed in to results with very strong new batteries things become very obvious and since they cost next to nothing or ..nothing they are easy to pitch (recycle) ..and when i recycle i often find more cells ..an endless cycle with the best cells floating to the top .
Ditto this, Willie Nails it pretty much. The only other thing I do is charge-cycle them a few times and let them sit for a 6-7 weeks on a shelf come back and test for LSD characteristics. Any cells that drop to less than 4.15V, I recycle them. This is a difficult test for most used cells to pass. I probably end up throwing out ~70% of the Sony, Samsung and Sanyo cells because they cant hold a charge.
I have found any cell that can meet all these criteria, will have sufficiently low internal resistance and is good for a tough 1-1.5C draw.
My best cell harvests always seem to be Panasonic CGR cells. Whenever I crack open a pack, peer inside and see them… Oooohh!! For whatever reason they hold a charge best, and really deliver on the current draw too.
ooh, you lucky gits getting Panasonic cells in laptop packs! I usually strike Samsungs and only really the last pack has yielded any with decent capacity (>1500mAh). Most of the cells I’ve harvested I’ve given away as backup cells for bike lights that I’ve made.
Sanyos and panasonics have been the best for me ..all the colors of the rainbow on the panisonics .orange purple,lt blue, lime green.
lest success with moli's (sorry canadians)...lg and sonys.. but i've seen very few LG cells
i have no idea what packs they came from...since you can't affect what packs are being recycled i stopped trying to care what cells came from what manufacture ...i think they also change companies as well .The last Dell packs were moli's i think and i expected them to be ....Sony ??
it's like christmas ...you never know what you'll get .:P
unfortunately the recycling centres around here won’t let me strip down batteries to test the cells, so the ones I get either come from request emails to my work listserv or ones dumped in the battery recycling bucket next to the recycling bins outside my lab. Still, it always feels good to give something another lease of life and prevent it ending up in landfill or wherever else li-ion batteries end up!
I found the teal CGR18650D in IBM thinkpad packs, and the purple CGR18650E Lenovo thinkpads. Its very rare though, almost all the cells I have pulled from Lenovo packs are red Sanyos.
Panasonic makes the best 18650 cells by far. I have used mine up to ~4A draw (almost 2C) and they don’t bat an eye to that. Their CGR cells test every bit as good as AW IMR branded cells.
interesting. I’ve only taken apart one IBM pack and it had something pink or red and not very good in it. I agree wholeheartedly about how good Panasonic cells are though - I bought a bunch of the CGR ones off Rev.Jim and use them in bike light packs, plus I’ve built a couple of NCR18650As into a helmet light pack for a friend.
Ha! I thought they only used those rinky dink li-po packs that you find in bluetooth earpieces Those posts were one hell of an eye opener. I’m half tempted to break apart one of my (refunded) eBay 18650s - 500mAh capacity and the internal resistance of a large piece of glass.
