So I have a large number of used laptop batteries, about 80 packs. There are three kinds one type has 9 18650s in them and the other two have 6 18650s in them. So needless to say I have way to many. Is there a market for these old 18650s? or even the packs? I am guessing if I were to pull them all it would be around 500 18650s.
It would take a long time, but if you could verify the capacity and quality of the cells that would be for the best.
What might work even better is if they are all identical packs (same brand/capacity for the 9 packs and 6 packs), verify the type of cell(capacity/viability) in the each type of pack and then sell the other packs as whole units instead of breaking all the cells out.
Used laptop packs are most times not worth it. Sorting through them to find the completely dead cells, the ones with 30% capacity remaining, and the 'good' ones with 60%... not worth it. Laptops are incredibly unkind to their batteries. Old but unused laptop packs are a different story.
Toss all batteries that measure under 3v (3.2 to be safe)
If you can, try to check what year are the laptops that run these batteries made in. Anything over 6 years could be tossed.
If you have a charger that can measure capacity (ex:imaxB6 for 20$ on ebay) you can test the capacity of the battery by discharging it after you fully charge them.
I think you should wait until someone wants these batteries, then take them apart. You can give them an option of having solder tabs or not.
By the way, you can use the battery packs as actual battery packs. They come with a built in protection board and thermal resistors. Just solder your plug to the + and -
Ok Red I have opened 2 packs, 18 total batteries. None have been lower than 4.02v
Dark green, 1 pack, 6 batteries. Range from 3.03-3.43v
Neon green, 1 pack, 6 batteries. 2.4-2.9v
There's more to it than that. With age they build up internal resistance, you need to do discharge tests on all of them and compare the capacity at low current with capacity at high current (usually 1 amp is good enough). The ones with a large spread between low & high current are junk, regardless of their resting voltage or how well they maintain voltage after charging.
