Love em or hate em? I have the stainless steel version, with some mods 8^)
I wear this nearly every day, mostly just as a piece of man bling but it does have a couple of handy features to it especially now it has added Torx bits #10, #8, #6 plus the 2mm & 1.5mm hex bits for adjusting scopes, knife pivots on the go etc.
On this one I have reversed the joint piece orientation, added a leather patch to the clasp underside for a more comfort fit, installed magnets to the clasp for extra closure security and made use of the hex shape holes by installing magnets and moulding JB Weld to store the flat bits.
There's a diamond file square, ferrocerium rod piece and four white tritium vials installed too.
I have also made a Flashlight Bit.
This operates like a slide switch. It’s held in by friction.
There is a small check out of the back corner of the unit and a corresponding piece of copper press fitted into the leatherman segment so you push the LED unit back into the body until it makes contact and push it from the back to turn it off.
The two SR364’s are in series with kapton tape lining the body segment.
Magnetic Clasp and Bits detail.
This usually accompanies my UK carry modified Skeletool CX.
Leatherman Wave with hacksaw mod and hand made molle sheath.
Feel free to share your Leatherman mods here too :THUMBS-UP:
