You have to learn how to make things better. Read this forum for a month or a year to understand what is all about
I’m happy to tell you I was wrong, :person_facepalming: I was 100% sure it was plastic, but it’s actually metal, I don’t know exactly what if aluminum or steel or whatever
What was talking about about a separate battery with screws?
Yay, so there is some potential to get the heat out.
The screws bit was about making a new battery pack. I’d probably throw away the old one because it’s likely no good with Chinese manufacturers cutting margins as tight as possible.
is this risk avoided by being made of metal? or is there still a risk even with metal?
The plastic part starts from the support, from the blue arrows
Yes, there is still a risk of overheating with metal if you give a light too much power, but you probably won’t need that much power for this light.
The metal will help dissipate the heat outwards from the LED.
However, I would gladly entrust you with the work, but I fear it takes too long between various expeditions.
Would it be so difficult if I made it myself? or maybe entrusting some parts of the job to an electrician? would he know how to do it?
So I should buy a DIY battery and a driver. Could you recommend these two things specifically? based on the characteristics and considering the SAMSUNG LH351D WHITE 5700K HIGH CRI90 that will come to me, always avoiding the overheating factor
I think it would be fine with 1.5A, maybe 2A at most if the heat path is alright. That’s a lot of light, maybe even too much up close. The body would get hot, burning to the touch, but the LED would be fine. The problem is we don’t know what the inside looks like and the heat path might not be so good (unlikely I reckon).
I’m not familiar with the drivers available for battery operated high powered leds outside of the flashlight world. I don’t think there is much out there that would work well so I do recommend getting help from someone here.
I’d recommend a 7135 driver attiny 85 driver where you could load a modified anduril with only the ramping up and down, and solder that to a battery bank with the output connected to the 5.5mm port, which looks like what your light is using.
I would also recommend a 4000k sst-20 instead of the LH351D since the sst-20 will make red colours look a lot more accurate.
My hope is that someone in Europe will read this and be willing to mod it for you.
What might work pretty well is if you could get an adapter that plugs into usb power banks and uses that 5v dc to power a driver that is connected to your light’s dc port. You could just buy power banks to power your light
This is a brilliant idea, but I don’t think it’s done right, how would the driver fit into all of this?
I’d try different, maybe easier approach.
Forget about using original power supply, host and LED.
Buy one of USB-C charged flashlight that works even without battery, while head of the flashlight has USB plugged in (like e,g, in some Wurkkos or Sofirn).
Chose flashlight with high CRI, Anduril, warmer tint, thrower or flooder - whatever you like or more experienced BLF members advise.
Attach mechanically head of the flashlight to original mounting, connect the lamp to power bank or AC/DC charger and test it. There’s a chance that light strength and pattern will be good enough for you even while USB powered (somehow limited in comparison to battery work-e.g. without turbo). With Anduril you’ll be able to adjust UI to your needs.
(we know only original LED type right now, not the current if I’m not mistaken? If so, it’s hard to say how much light LED gives now, with original controls).
No electric skill needed, only coming with some mechanical solution.
In worst case scenario you’ll have new nice flashlight, in best - problem solved.
Buy one of USB-C charged flashlight that works even without battery, while head of the flashlight has USB plugged in (like e,g, in some Wubben or Sofirn).
Chose flashlight with high CRI, Anduril, warmer tint, thrower or flooder - whatever you like or more experienced BLF members advise.Attach mechanically head of the flashlight to original mounting, connect the lamp to power bank or AC/DC charger and test it. There’s a chance that light strength and pattern will be good enough for you even while USB powered (somehow limited in comparison to battery work-e.g. without turbo). With Anduril you’ll be able to adjust UI to your needs.
(we know only original LED type right now, not the current if I’m not mistaken? If so, it’s hard to say how much light LED gives now, with original controls).No electric skill needed, only coming with some mechanical solution.
as a structure of the torch the one I have is fine because it is suitable as dimensions for my use, I would just like to try to enhance this
Whatever works for you
Main advantage of existing unit I see is small weight to be honest, not much more.
Exactly and it is essential that it is light, because it is something that is added to surgical glasses that are already quite heavy in themselves.
Or you could just use a modified flashlight body to hold a battery.
The flashlight body act like be a portable battery pack. I like this solution the best.
Take a Skilhunt H04RC, replace the led in the head with the correct dc port, and it’ll power your light for several hours on one charge. You just have to remember to never double click the switch and accidentally enter into turbo mode.
It has very consistent output and its non-turbo levels shouldn’t make the light become too hot.
You can buy an H04RC, solder in a dc port and even just add hot glue to glue it in. This is the easiest and best solution imo. If you find your light getting too hot, just disable the highest modes. The light even has convenient usb charging and you can always pop in a new 18650.
Unfortunately I’m not very experienced, I don’t understand what you advised me, to use the Skilhunt H04RC as a battery or as a led?
If you recommended this flashlight as a head-mounted led system, it’s too heavy and big!
I hope someone in europe reads to be able to help out!
So you buy this light. It is your driver and your battery pack that you can clip onto your belt or put into your pocket.
You remove the screws at the front, take out the optic/reflector, remove the led from it the H04, and solder on a DC port that your existing light’s DC port fits into. So you replace the H04’s LED with a dc port, then you hot glue it so everything stays in place in the head of the H04. You then plug your glasses light’s dc port into the modified H04 which acts as the battery pack and driver.
Photo credits lumeniac
Replace the optics and the LED port seen here with the correct Dc port, or you can just solder the wires directly together.
To do this mod you just need a soldering iron, the right screwdriver, and a hot glue gun to glue everything together. Then you will program the H04 using its instruction manual to get the modes you want.
It looks like the H04 is current regulated instead of temperature regulated so your LED body should stay relatively cool on most modes except the turbo ones.
Replace the optics and the LED port seen here with the correct Dc port, or you can just solder the wires directly together.To do this mod you just need a soldering iron, the right screwdriver, and a hot glue gun to glue everything together. Then you will program the H04 using its instruction manual to get the modes you want.
thank you very much for the support, this is also a good solution, but I would prefer something that was shaped like a bat, I believe that in the end I will buy a “7135” chips with different energy modes in order to adjust the intensity, and that it gives me a power of 350-380 mha.
And for the battery, box with 2 × 18650 batteries.
Now I would like to understand, to be able to build it, will it be necessary to buy and adapt the 5.5 mm port too?
Could you help me in the specific choice of specific materials to buy? Maybe even with links?
Thanks so much!
Up!
I don’t know what you mean by something shaped like a bat.
The H04 body will be a battery pack that clips onto your belt or goes into your pocket.
The H04 is the best, easiest, and most effective option. Using 7135 chips means you’ll need a mcu that needs to be programmed or you won’t be able to adjust the brightness. You will need to be able change some code if you go that route otherwise your options are rather sparse.
I’m not sure if your light plugs into a 5.5mm port, it may be 3.5mm or something else, you’ll need to figure that out for yourself. There is almost no good option for a battery box without you doing your own programming for a driver or manage to find some usable driver. The H04 option is the best and easiest one.
My offer to mod it for you is still on the table if you don’t think you’ll be able to do it yourself. The H04 route is very straightforward, you just need to do some soldering and using some hot glue
The H04 body will be a battery pack that clips onto your belt or goes into your pocket.The H04 is the best, easiest, and most effective option. Using 7135 chips means you’ll need a mcu that needs to be programmed or you won’t be able to adjust the brightness. You will need to be able change some code if you go that route otherwise your options are rather sparse.
I would like to entrust the work to you, but being too far away, I would like a quick result to understand what light I can manage to create and eventually change the product completely
Would the H04 respond to the characteristics I am looking for?
would the situation improve compared to the use of the battery that I already have of 3W?
And would the driver inside be compatible, and would it provide the ideal power for more light?
Thanks again
