Hi, I'd try to create a good LED lighting system for my surgical glasses
My goal is to create a LED similar to the top of the range, there is a few links here to understand its characteristics:
1) https://www.orascoptic.com/products/headlights/spark
2) https://www.zeiss.com/meditec/us/products/neurosurgery/loupes/eyemag-light.html#technical-data
3) https://www.univet.it/en/product/eos-wireless/
These instead are images of one of these disassembled LED systems:
I bought a LED spotlight from Aliexpres, whose base structure is good but I would like to strengthen it because the LED, which seems to me to be 12 mm, is not too strong, maybe it's a CREE XP-G2.
Spotlight structure:
Battery in my possession with 3W intensity adjustment (fundamental there is the intensity adjustment)
This is the light that makes me, with a spot with a perfect circle and the right size, a little greater than an open mouth:
First of all to upgrade this led system, I bought a Samsung LH315D with 5700K and 90 CRI with a 10mm MCPCB, hoping to be able to fit it into the 12mm Cree housing.
From what I understand, it should improve but not by much, so I would like to understand what I can change again, from what I know I should change now:
- the lens
- battery driver
Is it easy or is it complicated?
Would I have much better results similar to the led systems of leading companies, or would it change little?
If anyone knew how to guide me in this choice by advising me what to buy I would be grateful. Thank you
