Hello gents.
I have the pleasure of repairing a lenser P7 for a work colleague, which I think has a dead emitter. It looks like an XR-E, sat atop a small pedestal which is part of the pill.
I have voltage out of the battery carrier when operating the switch, so I think the problem is at the top. There is no driver as such, just a blank board connected to the LED via what looks like a resistor. I guess the problem could be the resistor - I’ll check it out tomorrow when I have access to the light again.
If it is the LED, would it be worth trying to upgrade? I reckon an XM-L would go in there, but I understand that there are some much better XR-Es available now. Bearing in mind the lenser uses a purpose designed aspheric type lens, would an XML work well in this setup?
Also, how exactly is the voltage/current regulated for the modes (H/L/Turbo)? At first I thought it might be some sort of resistor assembly in the switch itself, but I was measuring differing voltages from the battery pack with no load, so I’m thinking maybe the batt configuration changes between modes. I’ll have a proper look tomorrow.
Any help appreciated! ![]()
