LED Spectrum Simulation Tool for Mixing Different LEDs
I have developed a tool to calculate the resulting spectrum when combining various light sources with different spectra. Naturally, the modeling tool is primarily designed to work with LED spectra.
The idea for the tool arose while refining my tool for digitizing LED spectra from datasheet screenshots.
Below is an image of the main interface of the LED spectrum simulator. As with the first tool, I will use non-standard Bridgelux Thrive LEDs as an example. The spectrum was simulated using 4 distinct LED channels: two channels consisting of Thrive 5000K (100 units) and 3000K (50 units), plus Osram 660 nm and 730 nm at 3 units each.
A key feature of the spectrum simulator is the ability to switch the spectrum display between the radiant and quantum spectra. This allows the spectrum simulator to be used for designing specialized plant lighting.
The maximum number of channels available for calculation is 15.
To obtain the digitized spectrum of an LED or other light source, the first step is to use the LED spectrum digitization tool.
Next, for convenience, you can include the key LED parameters directly in the JSON or CSV file name. This is very convenient for subsequent work. It eliminates the need to repeatedly check the documentation and manually enter parameters. The parser is configured for parameters such as V, mA, Lm, PPF, or mW.
Let’s break down the file name Thrive_5000K_9.1V_100mA_108Lm.json:
  • Thrive_5000K - an arbitrary name, convenient for indicating the LED type and its color temperature or wavelength;
  • _9.1V - forward voltage drop of a single LED (for Thrive LEDs this is 9.1 volts);
  • _100mA - rated forward current of the LED according to the datasheet;
  • _108Lm - luminous flux of the LED according to the datasheet at the rated current (100mA). You can also specify the radiant power in mW or the number of emitted photons in PPF. The script will automatically recalculate any of the specified parameters.
From there, the parser works its magic and automatically maps all the specified parameters into the appropriate fields. All you have to do is set the actual operating current for the LED in the designed LED module and the number of LEDs in the channel.
Main parameters calculated by the LED spectrum simulator:
  • For each added channel, total power, PPF, and lumens are calculated separately.
  • Color temperature of the resulting spectrum.
  • Color rendering index CRI, CQS.
  • Total power of all channels.
  • Total luminous flux in lumens.
  • Total PPF and PPE.
  • Average luminous efficacy in lm/W.
  • LER value.
  • Circadian metrics.
  • Breakdown of the spectrum by ePAR ranges.
  • Chromaticity diagram and deviation from the Planckian curve.
Additionally, the spectrum can be colorized, compared with the McCree curve, compared with the solar spectrum, or compared with the blackbody spectrum.
After configuring the spectrum display, a full report in PDF format is available for download.
The resulting spectrum can also be exported in JSON or CSV format. You can then return to the spectrum digitizer tool to calculate color rendition metrics according to the IES TM-30 standard.
if you want anyone to uses an test your vibe coded tool (for a commercial site) make it at least free and open source and usable without registration.
has this since ever. they have even done it by hand no vibe coding and its still free, without registration and has a database of example leds
The main reason that you and me have this tools is mainly thank to the huge amount of freely accessible Open source / GPL code the
have Trained this models on. (without giving any credit)
this alone is at least controversial.
Giving credit to prior work now might be out of you ability.. but making sure to keep the core GPL Freedoms is.
Freedom 0 – Run: The freedom to run the program for any purpose.
Freedom 1 – Study and modify: The freedom to study how the program works and change it to suit your needs. Access to the source code is a prerequisite.
Freedom 2 – Redistribute: The freedom to redistribute copies of the original program so you can help others.
Freedom 3 – Distribute modified versions: The freedom to distribute copies of your modified versions to others, giving the community a chance to benefit from your changes. Access to the source code is a prerequisite.
I didn’t fully understand everything you wrote, but the main point is that I don’t actually need user registration. It’s simply an additional barrier to protect against bots. My server is relatively modest, with just 2 CPU cores and 4 GB of RAM, so I need to take measures to prevent it from being overloaded.
The tool remains free and accessible to everyone.
The main reason we have all these tools is the availability of a huge number of excellent Python libraries that already handle all the necessary calculations. I don’t need to implement all the formulas myself; I can simply use existing libraries.
I’ve added presets to the LED spectrum simulator for Samsung LEDs from the LM281B+ and LM301H series, with correlated color temperatures (CCT) of 3000 K and 5000 K, respectively. I’ve also added presets for Seoul Semiconductor’s SunLike 3030 LEDs with CCT of 2700 K, 4000 K, and 5000 K.
Unregistered users can add 1–3 channels using the available presets, plus one channel with a custom spectrum.
For each channel, users can either upload their own spectrum or select one of the available presets. Once a preset has been selected for one channel, it is automatically hidden from the preset options for the other channels. This prevents the same LED preset from being assigned to multiple channels when simulating the combined spectrum.
Open source = publish the source code under given license (GPL or similar) on a freely accessible platform (Github, Codeberg, similar)
without registration = what it says: no registration needed, make it usable with all features for everyone without putting some barriers in, which asking for personal data
Should I ever vibe code a tool, it will be open source. Especially since all LLM are trained on open source and other stuff, which is legally “interesting” by itself.
I understand what open source means; what I don’t understand is the criticism raised above.
As I’ve already explained, registration itself is not something I require. You can use a name that isn’t your real name, and there’s no need to provide a passport for verification.
I’ve invested a considerable amount of time and effort into this project, and it was never originally intended to be open source. However, the tool is completely free to use.
At the bottom right, there is now a panel with buttons for downloading the resulting spectrum in PNG or SVG format, without watermarks. These files are ideal for inclusion in reports or for use on a PCB, as shown in the example below.
The spectrum display depends in part on the checkbox settings below the graph. You can show or hide secondary spectra and switch between the radiometric and quantum spectra.
The huge number of excellent open source Python libraries
But you used a bot to make this…
The “Bot” trained on Open Source Code and used Open Source libraries.
And you use it to make something Commercial no Open Source.
Well i’m sure the libraries used as well as the code the Claude was Traind on from before the Vibe coding times also someone invested considerable amount of time and effort…
Maybe even more effort since most of it is hand wirten
Yes, that’s exactly what libraries are for, and they can and should be used for your own purposes. But I didn’t create a library. Most commercial products are built using existing libraries. I’d like to remind you that my product is not a commercial one.
Interesting claim. These days, everyone uses AI to offload routine tasks or find the information they need.
However, I don’t create tools with the help of a bot using the vibe-coding approach of “do it well, don’t do it badly.” At least for now, this approach seems to work only as a generator of digital garbage.
Maybe that’s true, but that’s a problem for developers to solve.
For now, AI is a good assistant, but not a personal employee who will do everything for you without making any mistakes.
