These LatticeBrights are everywhere in cheap Chinese knockoffs. This one is a 3.45mm package Cree XPE clone from a $3 SK68 clone I got from GearBest in 2015.
Here’s a datasheet for the LatticeBright XD-3535: http://www.latticebright.com/UploadFiles/Document/201705/18080550319626505.pdf
I of course can’t be for sure this emitter is that exact model, but the specs seem to somewhat correspond to my measurements.
Manufacturer’s specs
Forward voltage: 2.8-3.2V at 350mA
Maximum current: 700mA
Luminous flux: 110-165 lumens, 150 lm typical at 350mA at 25°C
Color temp: 5000-8000K, 6500K typical
CRI: Ra 70
LED package size: 3.45 x 3.45 mm
Going by the datasheet mine would be the lowest Q5 output bin (107-114 lm @ 350mA).
Test was done on an Al heatsink. MCPCB was put on top of a graphite thermal pad and clamped securely down with two screws. Tests were done in an integrating sphere.
Maximum output of 322 lumens is reached at 2.2A (3.18V, 7.0W)
Efficacy is passable at low currents but falls under 100 lm/W above 500mA.
Please note that the TM-30 numbers in the table above are from TM-30 version 15. CRI data later is version 18, which generally gives a bit higher numbers.
Color temperature is higher than specified and tint goes out of whack pretty fast when more current is applied. These should probably be only run at a couple hundred mA at most. LatticeBright specs them at 700mA max.
CRI Data
At low currents CRI is better than expected at Ra 76 and TM-30-18 Rf 74. It even reaches Ra 80 above 2A. This of course doesn’t really matter as the color temperature is horribly high at any current starting at 7000K on 100mA and reaching 9000K at 1400mA.
