Use the code ” LED-Driver” to purchase any LED Drivers will get 10% off in July includes the 5 years warranty Authentic Mean Well LED Power Supplies and other Dimmable LED Drivers.
Check the LED Music Controller for RGB/RGBW LED Strips, with audio input jack and audio connector, working in DC5V-24V, with 3 or 4 output channels design, max output up to 360W when works with RGB LED Light, the max output up to 384W when works with RGBW LED Light, the side with voice sensitivity dial, the 24keys RF Remote Control included, you can use it to adjust the brightness and change the color-changing style.
Silicone LED Channels, 5 meters per reel and cuttable, flexible and bendable, waterproof and dustproof, the inner width is 11mm and compatible with 10mm Flexible LED Strips,
can be used for outdoor linear lighting project in a wet, damp or water location.
4 In 1 LED Controller, you can use as a Single Color or CCT LED Dimmer, LED Controller for RGB or RGBW LED Strips. with 4 output channels, the max output power up to 576W when working in DC24V. there is a dip switch on the left top corner, you can switch the type of LED Light you want to connect to. the 2.4G RF Wireless Remote Control included, you can use it to turn on/off the LED Light remotely, adjust ght brightness, change the static color or dynamic modes, select the control zone and group control. one LED Controller for 4 types of LED Lights.
Recessed Aluminum LED Profiles, the standard length is 1meter and max length 3 meters per piece, can be cut to any length for your project. made of 6063-T5 aluminum alloy material and with silver anodized surface treatment, anti-oxidation resistance and has a longer lifespan. there are 6 types of diffusers available for the various lighting effects, you can choose the Opal Matte Diffusers, Semi-Clear Diffuser and Clear Diffuser. the inner width is 12mm and compatible with 8mm or 10mm Flexible LED Strips, the end caps with wire holes included, easy to connect to the LED Driver to light up.
the LED Alu Profiles have a flanged exterior lip to allow to be sunken into an opening with the flange to ensure a neat finish. you can use them as the main lighting or supplementary lighting under wardrobe, cabinet, kitchen wall, house wall, etc.
Check 16mm Drywall LED Profile Light With Single Flange, the standard length is 1meter per piece and max length is 3meter, cuttable and you can cut to any size for your project. the inner width is 13.9mm and compatible with LED Strip Lights a width up to 12mm. the LED Drywall Profiles with single flange, and the flange with holes, easy to recessed into 5/8" drywall, floating ceiling, you can use them as linear lighting indoor.
Features:
Material: 6063-T5 Aluminium Alloy
Surface Treatment: Anodized Silver
Model: ALP084
Color: Silver
Inner Width: 13.9mm
Compatible With 3528, 2835 Or 5050 Flexible LED Strip Light
Diffusers: PC Diffused Cover
Standard Length: 1Meter
Other Lengths Available: 0.5Meter, 1.5Meter, 2Meter, 2.5Meter, 3Meter
Installation: Drywall Trimless Recessed
Applications: Recessed Into 5/8"(16mm) Drywall, Floating Ceiling
End Caps With Wire Hole/Without Wire Hole Included
Black LED Channels with up and down lighting design, the standard length is 1M and max length can do 6M, cuttable and custom lengths available, there are 6 types of diffusers available for various lighting effects. the PVC anti-skid covers are included, which allows to walk on the LED Channels and not damage the LED Channels. you can install them on the steps or stairs for indoor decoration.
Check the LED Strip Housing for 28mm shelf board, with up down lighting design, max length can do 6M and cuttable, there is one type diffuser available, the PC diffused cover for the smooth light output. the inner width is 10mm and 1.5mm, allowing the max-width of LED Strips is 10mm, easy to install and light up.
The Recessed LED Diffuser Profile with long flange, you can recess into the drywall for interior lighting projects. the max length can do 6M and cuttable, the inner width is 15.2mm and allows the max width of LED Strips is 15mm, recommend installing high-density COB LED Strips as the light source. only PC diffused cover available for the smooth light output.
Silicone LED Strip Cover for outdoor lighting projects, 16.4FT per reel and cuttable, you can cut to any length for your project, the LED Light Covers are made of silicone material, flexible and bendable, various width products available, recommend installing the COB LED Strips to create seamless linear lighting, no visible light dots and dark areas.
High Voltage AC110V COB LED Strips come with US plug, easy to connect to the public power system directly to light up, 320 LED chips per meter and 10 meters per reel, the waterproof level is IP67, you can use them for outdoor lighting projects, the chip-on-board technology to create a smooth and seamless line of light, no visible light dots and hotspots, uniform light emission and high CRI 80+ for quality color rendering. the COB LED Strips are sealed with a silicone tube and filled with silicone material, the waterproof level is up to IP67, you can use them for outdoor applications and install them in a damp or water location. there are various emitting colors products available, you can choose for various scenes. you can use them in hotels, cabinets, theatres, clubs, shopping malls, exhibitions, bars, dance halls, museum lighting decoration or edge backlighting.
The 9W RGB+CCT Outdoor Sconce Wall Lights, which with modern design, square and round shape available, the color of shell is black. the waterproof level is IP66, works on AC/DC24V, 9W max power consumption, you can use them for the outdoor lighting projects on the wall. can be controlled by Zigbee Remote and APP to set color, adjust the color temperature and brightness for various scenes.
Features:
Model: WA5-09S-ZL(Square) / WA5-09R-ZL(Round)
Working Voltage: AC/DC24V
Power: 9W
Rated Current: 0.38A
Color: RGB+CCT
16 Million Colors Available
Color Temperature Adjustable: 2700K-6500K
CRI:> 80Ra
Luminous Flux: 720LM
Luminous Efficiency: 80LM/W
Illumination Distance: >8m
IP Rate: IP66
Wireless Technology: Zigbee 802.15.4
Zigbee Wireless Frequency: 2.400-2.480GHz
Control Distance: ≤100m(Open Area)
Zigbee 3.0 Remote Controllable(Zigbee 3.0 Gateway Needed)
Saturation Control
Stepless Dimming Brightness
Support Smart APP Controllable(Zigbee 3.0 Gateway Needed)
APP Name: Tuya Smart
Support Third Party Voice Control
Works With Amazon Alexa, Google Assistant
Can Enter Into Philips Hue, IKEA TRADFRI, Echo Plus, Echo, Echo Studio, Echo Show Standard Gateways
Installation: Wall Mount
Lifespan: 50,000 Hours
3 Years Warranty
This style of heavy Aluminum Channels can be used as handrails. With an up-and-down light design to light up the entire handrail. It’s perfect for any home or business that wants to add a modern and stylish touch to their handrails.
The LED Light Diffuser Covers are flexible and bendable; you can use them to design curved lighting indoors. The standard length is 5 meters per roll, and the maximum cand is 100 meters. They can be cut to any size, and allow the width of Strip Lights from 3mm to 20mm. They have a thin flange design and can be recessed into the slots on the walls, ceilings, and surface of the lighting projects.
The 12mm Bendable LED Light Channels can create curved line lighting for architectural and commercial purposes. They can be bent shape inside and outside and can be spliced arbitrarily. Three types of products are available: left-right bending, up-down bending, and full bending. You can use them to bend shapes inside and outside, and they can be spliced arbitrarily. You can use them to make circular, rounded corners, suspended, curved shapes on beams, walkways, internal corners, external corners, floors, stairs, baseboards, walls, ceilings, etc.
