Hello, guys, this is John from ledbe.com, now we added more new LED Drywall Channels for your interior design.
For more information, please check here: LED Drywall Channels For Plasterboards, Sheetrocks
Black recessed Channels with anti-glare design, 1M and 2M length available, the max length can do 6M and cuttable, there are 3 types of diffusers available, PC diffused cover, PC Semi-clear cover and prismatic cover, the inner width is 13.4mm, easy to install SMD LED Tapes and COB LED Strips inside.
Check the Recessed Light Fixture Housing for drywall, which are made of 6063-t5 extruded aluminum material and with anodized surface treatment, there are 3 colors available, the default color is silver, you also can take white and black colors. the standard length is 1M, other lengths are available: 1.5M, 2M, 2.5M, 3M and max length 6M. there is only one type of diffuser is available, the PC diffused cover, which is made of imported brand material, anti-yellowing, perfect light distribution and smooth light output. the inner width is 10.5mm and allows the max width of LED Strips is 10mm. recommend installing the COB LED Strips to create a seamless line of lighting for indoor projects.
Features:
Model: ALP068-SR1
Material: 6063-T5 Extruded Aluminum
Surface Treatment: Anodized
Colors: White(Default), Silver, Black
Standard Length: 1M
Other Lengths Available: 1.5M, 2M, 2.5M, 3M And Max 6M
Custom Lengths Available: YES
Diffusers: PC Diffused Cover
Inner Width: 10.5mm
Max Width Of LED Strip Lights: 10mm
Max Power: 12W/M
Beam Angle: 100°
Tolerance: ±1%
IP Rate: IP20 Non-waterproof
End Caps With Wire Holes Included
90°, 90° Vertical And 180° Connectors Sold Separately
LED Strip Lights Not Included
Installation: Recessed Into 12.5mm Drywall Or Plasterboard
5 Years Warranty
The ALP129-O is the recessed LED Housing for 12.5mm outside corner installation, the standard length is 1M and max length can do 6M, you can cut to any length for your project, the inner width is 5.5mm and allows the max width of LED Strips is 5mm, recommend installing the COB LED Strip Lights inside, no visible light dots and dark areas. the compact design allows for a seamless plaster-in installation inside the 1/2” drywall without having to modify framing, easily recess in walls, ceilings and tight spaces or corners to cast beautiful, diffused and even lighting throughout your space. the LED Light House with flanges and the flanges with honeycomb holes, easy to mount on the wall with screws, plaster and painting on the drywall.
the Drywall LED Channel for inside corner of 12.5mm drywall plasterboard, the standard length is 1M and max length can do 6M, you can cut to any length for your project. the inner width is 5.5mm and allow the max width of Flexible LED Strips is 5mm, recommend installing the 3mm, 4mm or 5mm COB LED Strips as the light source.
ALP071-S Trimless Recessed Lighting Channels, the standard length is 1M and max length can do 6M per piece, cuttable and you can cut to any length for your project. the inner width is 20.7mm and allows the max width of LED Strips is 20mm, easy to install a single row or multiple rows COB LED Strips as the light source. only PC diffused cover available for the smooth light output, no visible light dots.3 types of connectors sold separately, you can use them to reconnect the LED Light Channels together and use for the lighting project from ceiling to wall.
Link: Plasterboard Trimless Recessed Lighting Channel With Diffuser
The ALP084-S Recessed LED Strip Light Fixtures, which with a single flange, the flange with small round holes, which easily can be recessed into the wall or ceiling for indoor linear lighting, plaster and paint on. the standard length is 1M and max length can do 6M, can be cut to any length for your project. the inner width is 13.9mm and allows the max width of LED Strips is 13mm, recommend installing high-density COB LED Strip as the light source, no visible light dots and dark areas, brighter and uniform light emission.
We added the newest LED Sheet products. They are good options for the backlighting in contourtops, display boxes, signs, shopping windows, etc. They are flexible, bendable, cuttable, and linkable. You can choose single color, dual white, RGB, RGBW, RGB+CCT, and addressable products. More details, please check here:
The single-color dimmable LED sheet panels are ultra-thin, flexible, bendable, cuttable, and linkable. Great option for backlighting in advertisement boxes, signs, marble countertops, shopping windows, etc.
Link: Flexible 2835 White Dimmable LED Sheet Panels Cuttable DC24V
The newest, narrowest 2mm COB LED strip lights can be installed in narrow or limited spaces in furniture, cars, trucks, toys, etc. The standard length is 5 meters per roll and can be cut.
Link:
[images removed]
10-meter-long flexible sheet lights for large back lighting projects.
They use high-quality 2835 SMD LEDs as the light source for uniform lighting.
Bendable, cuttable, and connectable. It can be bent and conformed to curves, corners, and irregular surfaces.
A strong self-adhesive tape backing and screw holes for quick, easy installation.
Ideal for signage, lightboxes, countertops, and backlit panels.
Individually addressable WS2811 LED string lights, you can choose IP30 non-waterproof and IP68 waterproof for indoor and outdoor applications. Can work with SPI LED controllers to achieve magic lighting effects for Christmas, holidays, and events.
Link: 5V/12V WS2811 Individually Addressable LED String Lights
https://budgetlightforum.com/commercial
Please post only links to images from an external website instead of uploading images to BLF.
Please DO NOT upload images to BLF. Instead, post links to images from your own website.
Oh hey - I’ve installed this pattern before!
I wish I’d used normal channels vs whatever the hell it was I installed here. It was tricky, and I did not have a miter saw at my disposal - so I cut all of these joints with a handheld hacksaw! I also sloppily hung all this sheetrock because we couldn’t get the crew there on time!
edit: the company I used to work for was garbage, and I did all of that work by myself!
Sorry to know about your bad experience. Yes, with our aluminum light channels, which will make it easy. Glad to see you have done it by yourself.
The WLED remote controls have 9 buttons for Gledopto WLED LED controllers. This can be used to turn ON/OFF addressable lights, adjust brightness, enter sleep mode, and call the preset lighting effects without using the phone app.
The LED handrail channels are designed to integrate lighting along the walls beside staircases or passageways, providing illumination and modern architectural elegance. They feature an up-and-down lighting design that delivers optimized angle lighting on both walls and floors, improving visibility, enhancing safety, and creating an ambient effect. The PC diffusers evenly spread the light, providing uniform illumination. Ideal for staircases, corridors, and passways in residential, commercial, and public spaces.
