I guess thatâs my point exactly. UV LEDs require a boost driver to run off 3.7v and lower, a buck/linear at 4.2v. But problem solved if you go to a two battery solution and driver, but not feasible for a Convoy as marketed. (Please letâs not get into CR123s - whole ânother set of problems).
UV emitters range from 3.7v to 4.2v. Out of the hundreds of LG parts Iâve used, the ones I have tested are all 4.0v. The Nichias I have tested are also 4v. I wish I could get the lower voltage bins, but not easy, and probably pricey? 7135s will drive the LED at its Vf as long as you supply a tad more at the input.
Assuming 4V, even at 3.3V youâre looking at a worst case scenario of 18% sag. Visibly would be difficult to see. Youâre really splitting hairs for your conspiracy theory and again, the current is never 700ma @ 4.2V
Not splitting hairs. Measuring UVA output with a meter. The drop is significant. Not a conspiracy theory - simple design. But Iâm worried about the mass market for flashlights sold from China, not the great lights that yâall build here and fine tune for every last photon. Love that part of this hobby, but I have to design for the masses, and it has to be a reliable product. LG parts must be derated starting at 25-30c - expecting the Convoy to reliably dissipate heat well enough for one of their UV LEDs driven at 5.8W is wishful thinking (IMHO).
Have you tried the new not-so-new LG LED which is the subject of this thread? The Vf is 0.3v lower than previous offerings, so it should keep in regulation a longer time in a linear driver. However it wonât be almost a point source like the Nichia.
No problem hijacking this thread pirateo, it is good practice on BLF
I think something should be noted about the Convoy UV flashlight: since Convoy changed from the Nichia 276A to LG 365nm leds, the leds are reflowed on copper DTP boards which makes an immense difference in heat shedding of the led. It improved 3 things:
1)the 276A seemed a very sensitive led to damage while the LG leds seem to handle abuse better (this is my impression at least)
2)the aluminium board that Convoy used for the 276A had about the worst thermal properties that a ledboard can have. I tested it against my own custom (non-DTP) board and my board was miles ahead (link)
3)DTP boards have proven to shed heat way way better than non-DTP boards.
I think that there are still many 276A Convoy UV flashlights in shops around the world but the newer ones with LG leds should hold up much better (and not the least because of the ZWB2 filter)
That said, if the led should be kept under 40degC for keeping performance in the long run, my estimate is that in an S2+ host with DTP board the current should be kept under 1 A. But for occasional users that may not be needed and they can run it at 2A and have a bit more output.
Btw, at 1 A, the LG led of the OP has a voltage of 3.55V, assuming 0.3V loss in the circuitry at 1A current, the battery should deliver 3.8V to keep the 7135 chips in regulation. A modern but cheap high currrent cell like the Samsung 30Q can keep 3.8V at 1A for about half the drainage of the battery, the other half will show slow dimming of the flashlight.
FYI, I recently bought a Nichia S2+ and it definitely uses a DTP board
Yes, my latest batch of 100 are the ânot so newâ parts, and what you say is true. But still they fall out of regulation too quickly, depending on the battery. For minerals we prefer the broader beam vs. point source (cover more ground that way) but are always looking for max UVA output.
This graph might be of interest to the group. It shows a Nichia 233b and how the UVA output drops off as the battery voltage decreases (classic Convoy w/ 7135 drivers, drops to less than 1/2 max output @4.2v when at the rated voltage of the battery (3.7v). 1050ma).
Thanks Djozz! Iâve done it before, mostly your threads
Yes, the copper boards are a major improvement. But given my testing, I donât think very many flashlights in our userâs hands are being driven at 1A (or higher - in spite of claims). We have thousands of users and I have had zero failure reports (I donât sell/make them - I just run the hobby group which uses them). The high Vf and low battery voltage simply insures that they are not driven as hard as the manufacturers claim.
FWIW - I built two 9W Convoy M3 using the 2A LG part (LEUVA66X00RV00) with quartz window, copper boards, potted, and higher volt driver. Used them both heavily at a big rock show this past week, great results. But I just build flashlights for my own pleasure.
I will check into that!!! Batteries are a big issue. We have grandmas and grandpas buying any old piece of junk on Ebay. Hard to convince them to pay the extra $$$ for a good battery
The grandmaâs and grandpaâs should be checking in on BLF a bit more often and learn how to swap the springs for low resistance ones and use the latest batteries . They chose to mess with the highest voltage leds around (the UV ones) , that requires some extra measures.
The current problem on BLF is quite the opposite: the newest white leds have so low voltage that lineair drivers struggle to burn off all that overvoltage
Wish they could, but they are just buying lights from China and US manufacturers who are exaggerating claims, and building crappy lights. They are clueless about flashlights and canât even spell BLF
If they know not to short the batteries they can use unprotected batteries, which are cheaper. You want the Samsung 30Q (the LG HG2 is slightly worse), Sony VTC6 or one of the ~3500mAh batteries (Sanyo GA, LG MJ1, Samsung 35E, Sony VC7). All of those have about the same discharge curve at high SoC. The Samsung 26F is cheaper but the voltage curve is certainly worse, I would avoid it. 4.35v max/3.85v nominal batteries may be slightly better but also more expensive and harder to find.
In UV flashlights overdischarge is not really a big issue because of the high Vf of the LED. A Liitokala or Zanflare Lii-100 can charge both 3.7v and 3.85v batteries for $6 and should be safe enough (unless the user changes the mode to 3.85v for a 3.7v battery, they are not foolproof). Edit: If 3.85v batteries arenât used the â Xtar MC1 Plusâ:https://www.illumn.com/batteries-chargers-and-powerpax-carriers/chargers/xtar-ant-mc1-plus-li-ion-usb-charger.html is cheaper and more foolprof.
Protected batteries have a bit of additional voltage drop, which should be accounted for, but Iâm not sure if it will have a measurable effect at 700 or 1050mA. The main issue with protected batteries is fitment, they may not fit in the Convoy S2+.
Thanks for all the suggestions on batteries - I will check them out. I may try to convince the manufacturers into supplying a good battery.
As far as fit, I donât see a problem with protected batteries unless the springs are changed and fitted with copper tips (as they should be, but arenât). Maybe then a problem?
Where did you see âConvoy S2+ 365nm False Power Claimsâ about 5 W?
Just to avoid confusion: As of today the genuine Convoy shop (buy somewhere else and you may get something else) is selling three types of UV LED flashlights:
- S2 grey, ZWB2 filter, 1750 mA driver with LG LEUVA33W70RL00
- S2 black, ZWB2 filter, 1050 mA driver with unnamed LG, likely LEUVA33T00RL00
- S2+ black, no filter, 700 mA with unnamed Nichia, likely NCSU276AT
There is some fuss about copyright claims on filters so the Nichia S2+ without filter is the only option for US buyers. (Change âShip toâ country to see all three.)
That's not correct, as soon as constant current can't be sustained linear driver enters into so called dropout mode which is nothing else but direct drive (fully opened transistor).
I probably should have used another name instead of âConvoyâ. That name has become like Kleenex in our fluorescent mineral hobby. Any 365nm light in the Convoy form factor we call a âConvoyâ. But there are many knockoffs - Jaxman and others, all marketing various current - 1050ma, 1400ma, and have even seen a 1750ma light. Of course their wattage claims are all over the place, but most commonly I see 5W/6W (for example: Amazon.com). 3.8W here (along with dubious patent claims): Convoy S2+ UV 365nm LED Flashlight | Way Too Cool LLC. There are several others, lots from China (Fenix?, noname, etc.) https://www.aliexpress.com/item/Convoy-S2-Grey-7135-5-365nm-5W-UV-Flashlight-Fluorescence-Sterilization-One-Mode-With-Hand-Strap/32968137300.html?spm=2114.search0104.3.36.dc303783kl14qB&ws_ab_test=searchweb0_0%2Csearchweb201602_1_10065_10130_10068_10890_10547_319_10546_317_10548_10545_10696_453_10084_454_10083_10618_10307_537_536_10902_10059_10884_10887_321_322_10103%2Csearchweb201603_6%2CppcSwitch_0&algo_expid=0ca0b322-01f6-4aab-89a9-46a761fba0ad-5&algo_pvid=0ca0b322-01f6-4aab-89a9-46a761fba0ad&transAbTest=ae803_4&fbclid=IwAR2prQ-aMLyCXwOBEbElp6T5KT6jELdd2ziK7nNqY82WHNloJW7pM3AEeGQ
Actually the fuss is about a patent, silly. Agree, the Convoy is as above, but there are many copycats. In our hobby the word Convoy is used like Kleenex here in the US - a generic term.
Jaxman, Convoy, and Sofirn are all legitimate brands.
@pirateo40, that Amazon listing is doing some false advertising, and the light itself is waayyy too expensive knowing that Jaxman sells it at half the price.
And look at the 5th picture.
When they say 5/6W power, they mean power consumption, not power output/radiance.
