Light source using 3 different types of LED
Hi….
I want to make a light source for the garden in my balcony.
Well, i’m planning to use 3 different colors of LED (and a total of 7 LED): 3 x White, 2 x Green and 2 x Ultra Violet (Purple), but i don’t know which type of driver i should use.
The LEDs would be a 3W high power LED (that one with that “star” PCB) and the specs of each LED is:
:: White ::
- DC Forward Voltage (VF) : 3.6 ~ 3.8Vdc
  • DC Forward Current (IF) : 700mA
:: Green ::
- DC Forward Voltage (VF) : 3.0 ~ 3.4Vdc
:: UV ::
- DC Forward Voltage (VF): 3.2 ~ 3.6Vdc
  • DC Forward Current (IF): 750mA
I also want to have 3 [ON-OFF] switch, one for each color. Can i use just 1 driver for this, considering there will be simultaneously ON 2 (only Green or UV), 3 (only White), 4 (Green + UV), 5 (White + Green or White + UV), 7 (White + Green + UV) LED?
Thanks everyone, but i have no idea how to calculate the voltage and stuff.
Just another question: Should i need another heatsink mounted with each LED, or the “star heatsink” can do the job?
Thanks!
Gabriel
That’s often referred to as “fixed lighting” (as compared to portable flashlights)
Paste this into Google and it will get you a lot of background info:
"LED" - Google Search%22fixed+lighting%22%22DIY%22
and then on the results page /More/Image Search for pictures
Short answer from an amateur, better answers will follow:
Separate drivers (you don’t need flashlight drivers)
Screw the stars down firmly to a big piece of copper or aluminum to carry heat away,
plus a very thin film of thermal paste, but aim for metal to metal contact as much as possible.
Humm….okay!
Thanks :wink:
