Light that can use different batteries?
I was looking at the Lumintop SD10 becaused it could use different type batteries, but from the reviews, it doesn’t really make the grade. Is there another light that can use different batteries? I don’t have a small light that can use D cells, so one that can use Ds, AAs, 18650s would be great. If all it could use is Ds and another common type, that would also work. But it needs to be a single D or use battery carrier for AAs etc.
If not, I will choose between the Zebralight SC600 xm-u2 or Nitecore EA4. And any opinions on which would be the better of those two would be welcome. I am thinking the SC600 would be better, but can’t find any info on throw/flood or beam shots to compare.
it depends on how small or big you want the light to be.
SD10 is somewhat of a bigger light, ( almost the size of the EA4) and not really good for an EDC if thats what you need, but it does have the good versatility of using diferent cells.
There are many generic lights and mid-sized Ultrfires that can use both a 18650 & 3-AAA Alcalines.
For smaller lights EDCable there are a fiew, if you don’t mind the PWM the Ultrafire UF-T20 can work on AA, 14500s, 123s, RC123s.
I have an EA4, and mine only works on AAs.
Also the Fandyfire Rook works on both AAs & 14500s.
There are a number of more pricey lights too that have multi-cell capability.
If this is just for preparedness, then you can get AAA to AA adapters, AA to C and to D, adapters.
Mainly I’m just trying to get a light to fill a space in my collection. I have most everything in the common battery types, except a D cell. Well, I have D cells like the mag light and ordinary bulb types, but nothing like the SD10. A single D light, that can use AAs etc would be great, but if not, then I will fill the spot with something else.
If I can get adapters and make this work, that would also be great.
