I take it you are meaning the beam profile in flood mode? I too love the even illumination they offer vs traditional reflector lights.
I’ve got a couple of SK68’s and they are good usable little lights. I have a couple of other zoomies too.
My a country mile my favourite and one of my all time favourite torches ever is the POP lite T33.
It’s a 3xAAA light and is about the size of a Solarforce L2M.
$22 @ FastTech (+ BLF discount if you enter the code)
http://www.fasttech.com/products/0/10000890/1075602-pop-lite-t33-cree-xp-e-r3-220lm-white-led-zoom-fla
I did a review of the T33: https://budgetlightforum.com/t/-/17684#node-20508
In my opinion the TIR optic is many times superior to the aspheric lens used on most zoomies. The TIR doesn’t produce the cleanest beam if you are white wall hunting, but in actual use it is far superior. The flood mode is many times a larger area and in full zoom you get a larger round hot spot not an emitter image with lines (wires). So you see a bigger area at a greater distance and with greater clarity. The “dirty” rings you get on zoom look horrid on a white wall, but outside offer up enough ‘spill’ to walk by should you want to, but without being too bright to distract.
I’m also very much a fan of the 1 mode operation of the T33. The only downside is it doesn’t have the longest runtime, but it is comparable to most 1x14500 or 1xRCR123 lights I have and better than some.
I also have some other POP lites. The slightly larger T34 (4xAAA). This in reaity is just as good as the T33 in it’s ability. Although it is chunkier in the pocket despite using the same sized TIR optic. However I find I’m not overly keen on the UI and prefer the 1 mode T33 over the 3 mode T34.
Yesterday I also received the T22 which is a 1xAA light. It’s quite slick and fits in a pocket easily, although it is longer than an sk68. Thus far I’d say it’s the least impressive POP lite. Performance slightly exceeds an AA sk68. I think I will mod the T22 while I have no intention of modding the other ones.
Moving away from TIR zoomies I also received this a few weeks back:
$5.86
UltraFire ZB-006
http://www.fasttech.com/p/1133700
I originally ordered it as it claimed an XP-G emitter, during transit FastTech changed the listing to XP-E and as you can see in the picture the torch says JP-006 not ZB as per the listing.
I’m a bit annoyed at the emitter not being what I wanted. But I would say this is one of the best flashlights in terms of value for money that I own.
It’s very very compact, not much bigger than an sk68 and slimmer. And it out performs an SK68 (even one on a 14500) by a reasonable margin. It does get hot for extended use, likely due to it’s size. But it’s well worth the money and a good EDC.
I also have an XM-L zoomy. I got an sk68 clone, although one on a giant scale as it uses a 26650 battery for $12.99 off ebay. It’s a bit big and heavy for EDC, although fits in a jacket pocket ok. The XM-L offers more brightness in flood mode over the XR-E and XP-E emitter lights but can’t match them in throw. The XM-L has a lower surface brightness and just doesn’t project as well. Although the Aleto uses a larger lens and throws about as well as an sk68 on a 14500 does but with a slightly larger area.
More info here: https://budgetlightforum.com/t/-/16797
My last zoomy is a Trusfire Z8, this is a very nice looking ‘bling’ pocket torch. It’s my only zoomy that twists rather than slides. It’s a nice light to use and hold, and again on flood was very good, although it lacked throw in zoom mode due to being an XM-L and a small lens. It was adequate, but nothing spectacular. I also found the stock emitter to be way too cool, almost ice white. And being stainless it did get hot.
Since then I’ve changed the emitter to a Nichia219 which has a very high CRI. It isn’t quite as bright now although still throws a similar amount, but the colour rendition is just superb.
Last up I have also bought aspheric lenses from DX and fitted them to my Mini Mag and my 6D Maglite. I’ve made these non adjustable so they aren’t flood to throw. But they work well for their intended purpose which is wide area even illumination.
