Hey Guys,
I have been thinking about creating a light weight, compact lighting system for when I am in the bush/hunting/staying in huts and I wanted some advice.
I have a 18650 USB power supply that can deliver up to 2 amps at 5.5v.
I was thinking about having a couple of xml leds on stars inside a couple of frosted film canisters with some light gauge wiring hooked up to a USB plug to the power feeds etc.
My questions are:
1) If I hook the cree stars up, postive to negative on one site and negative to postive on the other, will they cope with 5.5v, i.e. is that in series so should cope with 6v+ etc
2) What would control the amp’s? Would two leds being hooked up in series at a lower than normal voltage result in a lower than normal current draw?
My ideal would be a couple of XM-l’s LED’s hooked up that I would be driven at around 1.5 amps with a warm colour tint.
Any suggestions, thoughts or comments would be appreciated. Also if you know another way that would achieve my goal but invovle no more technical expertise than I have clearly demonstrated above that I have. keep it simple s……… etc etc
Cheers
II’z
(Do the mouseover trick. Click for a surprise! Right-click=>View Image for larger.)
