LiIon VENTING Tests 2017! Round #2 / UPDATES July,17,2017
HKJ…. Is the venting gas dangerous to breathe? I have heard various opinions, ranging from almost immediate death to not really. :person_facepalming:
Since you have had it happen in what I am guessing was an enclosed area…. What say you…. from experience. :slight_smile:
Thank you in advance……… :+1:
Nice thread DBSAR, thank you. :+1:
one of the most toxic & serious gasses created during a Lithium-Ion battery burn/vent is hydrofluoric acid. (a compound of hydrogen fluoride, which causes severe & permanent soft tissue damage if breathed in. >> Hydrogen fluoride - Wikipedia
OK, I figured it probably was not good……
Thank you for explaining just how bad it is & can be DBSAR. :+1:
Depends, as long as the cell only vent it is not a problem, if you get flames it is problematic.
Thanks HKJ, that was/is what I was looking for.
  • Vent……. No Flame……… No problem
  • Vent……. Flame…………… PROBLEM … XXX … Do Not Breathe … XXX
Got it…. :+1:
Update to OP, ( Impact test added)
I’m sure thats a good thing that nothing spectacular happened. :slight_smile:
I’d like to see two fully charged 18650 in serie and shorted. That’s what may happen if you put one cell upside down in a SRK style light - not sure whether the two other cells would moderate or aggravate the short…
Well at least… just short a fully charged 30Q or VTC6 and let us see… :smiling_imp:
I will be doing those tests with 30Q cells once they arrive. (supplied by the Miller to do some safety tests on these cells as they are the recommended cells to use in the new BLF Q8.
Recently I accidentally shorted a high current LG cell (the dark brown one) and nothing spectacular happened: the internal fuse blew and that was that. I guess that will happen with two 30Q cells shorted in series.
How long did it take for the fuse to blow?
Seconds!
It happened inside a flashlight build. I closed the battery tube, clicked the switch and no light came out. Knowing that a direct battery short is always an option I immediately screwed off the tail again and the battery was gone and the switch was toast.
Too bad, but honestly this is a super nice feature. Accidental short is my biggest fear when it comes to lithium ion. Maybe you’ve read about the Acebeam K60 on CPF, and the Niwalker thrower with the electrical short in the carrier…
Do you know if all modern cells like GA, 30Q, and VTC6 are equipped with this internal fuse? How can you find out?
I think that I read in a HKJ article that all major brand 18650 batteries have a (non-resettable) internal fuse.
Interesting.
You can find test data for the 30Q at NKON’s: https://www.nkon.nl/sk/k/30q.pdf (interesting torture tests)
On page 14/17 you can find the short circuit test: 10 milli Ohm is applied externally. It seems more is happening than just the fuse popping, as the temperature rises to 100 degrees C for over two minutes. So I’m a little bit puzzled what to expect…
NCR18650GA: I believe the NCR series uses HRL technology instead of the internal fuse
HRL technology: http://business.panasonic.com/solutions-factoryassemblysolutions-featuresbenefits-batterytechnology
HRL technology in action: https://budgetlightforum.com/t/-/3132
The almighty press guy just posted this on YouTube
