Today I have the latest and greatest version of the Thrunite Catapult Pro. This is a long-distance handheld thrower flashlight. It uses an SFT70 LED, which results in an improved throw of over 300 meters out to 1005 meters, and a 132,500 candela improvement. On throwers, it’s that candela number that you are looking for not lumens. Thanks to Thrunite for sending this to me. I’m trying a little different order on this one, let me know what you think.
Watch this review on YouTube:
Follow me on Instagram: Jon (@liquidretro) • Instagram photos and videos
Join the Facebook Page: Liquidretro Gear & Reviews
Follow me on TikTok: liquidretro1 (@liquidretro1) | TikTok
Enjoy this review? Buy me a Coffee/Beer: https://www.buymeacoffee.com/Liquidretro
Find all my social media at liquidretro | Twitter, Instagram, Facebook, TikTok | Linktree
Buy the Catapult Pro from Amazon at https://amzn.to/3SQkURn (Affiliate Link)
Buy the Catapult Pro from Thrunite at https://thrunite.com/catapult-pro/#tab-description
LED & Beamshots
The Catapult Pro is using a Luminis SFT70 LED, this is a flat top LED and well known for its throwing capabilities. On my Opple meter, I measured about 6000k when in low, and it gets slightly cooler up to 6100k when in infinity high mode. CRI (Ra) measured at 68. The DUV showed it was just slightly green in person this is hard to notice. There is very fast PWM when using the infinity UI as you would expect, but high and turbo are free of it.
As you show from the night shots section the beam is what you expect out of throw, a very small, very intense hot spot, this has a small spill around it that’s about half as bright, and then the wider spill is very minimal. Compared with older versions the beam here is more intense and has a tighter more defined spot. This is reflected in the greater distance and improvement of 132,400 candela.
Output Testing
Turbo - 2450 out of Rated 2713 = 90%
Infinity High - 1620 out of Rated 1482 = 102%
Infinity Low - 50 out of Rated 42 = 119%
Heat and Runtime
Quickly let’s go through the heat and runtime here of the Catapult Pro. The light is able to sustain 1500 lumens or more for 9 minutes and it reaches 48C during this. The first minute and a half are good for at least another 1000-1500 lumens. In high mode the lights able to sustain the 1500 lumens for an impressive 14 minutes. Total runtime in Turbo and High are right at 1:50:00. I also tested by ramping to 1000 lumens and seeing how long it could hold this and that got me out to 2:17:00.
Packaging & Included Accessories
The packaging is the same as Thrunite’s standard brown cardboard box, with line drawings on the outside, and minimal info. Inside the light is well protected with foam. The accessories are the light itself, with a preinstalled 5000mAh 26650 protected battery, USB-A to C charging cable, nylon holster, branded lanyard, split ring, 2 spare O-rings, spare port cover, inner button material, and the manual.
Construction & Design
The Catapult Pro is a step away from the design we have known on the Catapult V6 and V6 SST70 versions. While the tail sections are the same, the body tube is where the difference shows. Gone are the milled diamond grip pattern which was one of my favorite things, and they have been replaced with more traditional rectangle milling that Thrunite uses on other lights like the TN series. Here the blocks are a little larger and deeper, it makes for an aggressive grip on the black anodized aluminum. Interestingly all 3 versions of the Catapult have interchangeable heads and bodies, and they all work with each other. Anodizing here is good quality and matches very well with other black Thrunite flashlights I have.
The light only separates at the top of the body tube right before the switch. Inside there is a beefy double spring in the tail and threads at the top are square cut, and nicely greased. The button is the same one that Thrunite uses on most of their models. It’s low profile and is a decent click for an electronic switch. Reverse the switch is the USB-C recharging port, with a good silicone cover that stays in place nicely.
The head design is similar to the TN42 V2 that I reviewed last year, where it’s a smooth cone on the exterior, silver bezel, large glass lens, smooth reflector, and a nicely centered LED.
Size, Weight, and Retention
With each revision of the Catapult, they seem to grow a little in size, and that’s no different here with the Catapult Pro. Length is 5.92” (150.5mm) long, 1.3” (33.5mm) in diameter at the body and 2.55” (65mm) at the head. Weight with the battery installed is 10.89oz or 308.6g. Weight increases only slightly 0.19oz over the outgoing Catapult V6 SST70 version.
Retention options are the same as previous models, there is a place for the lanyard attachment at the rear with or without the use of a split ring using the branded lanyard. Your other option is by use of the nylon holster. This holster has a very minimal amount of padding inside, it features a fixed belt loop and plastic Dring.
UI
The Catapult Pro has a change in UI, from Thrunites normal stepped modes to a ramping interface we have seen on a few other Thrunite lights. I don’t mind this because it allows for the user to dial in exactly how bright they need the light and optimize battery life. However here it’s just a touch slower than I would prefer.
The ramping interface works logically and has memory mode. It’s infinity ramping, so if you press the button and hold it the light will ramp up, flash twice at the top of normal brightness, and then start ramping down, where it will then flash twice and start ramping up again. Long press from off to get to firefly, Double Press in any mode to get to Turbo, and triple press from any mode to get to strobe. One interesting note here about strobe is that it doesn’t produce anywhere near peak output. It’s only rated to 776 lumens whereas the light is capable of producing 2700 lumens in Turbo.
Recharging
Recharging here is accomplished with the onboard USB-C. The port cover here is good, it stays in place easily. I had no issues charging the ligh with USB-C to C or with chargers capable of PD. I tested the included 5000mAh Thrunite button top protected battery at 5543mAh. From LVP at 3.159v to full at 4.156v in 3:20:00 with a maximum charge rate of just under 2A for about 70% of the charging time. Let me know how you like the graph here, I got some new equipment that gives a more detailed output.
Final Thoughts
I have been a fan of previous versions of the Catapult and the new Catapult Pro earns that spot and recommendation too. It’s a pretty big upgrade in performance over the previous version. It’s a significantly more focused, intense beam, and the result is 300 meters more throw than the previous version.
The UI here will be a hit-and-miss thing for you depending on if you like ramping UIs. For me it’s a touch on the slow side but good. It would be nice if they would allow you to switch between a Ramping and Stepped UI, but that’s not a thing here. I do wish they would have kept the diamond milling on the body, while the rectangles on the Pro here are more aggressive they just look like most other Thrunite models, and the diamonds of the previous Catapults I thought elevated the look of the light and made them stand out. Fear not, the body tubes are interchangeable if you have previous models and want to make a switch you can.
This is the biggest upgrade Thrunight has done to the Catapult line, not only visually but also for performance. If you want a handheld thrower that uses a single larger battery this one won’t disappoint especially with its fairly long duration on higher outputs.
