Lol. Beat me to it my 2 seconds.
Subbed, I think member Ryansoh was trying to get a LiIon to go boom before, I do not think he was successfulā¦
Perhaps a pre-heat to +160F if the room temp stuff is not working?
I want it to go boom from a direct short. Thatās what everyone is scared of. No preheating. Iāll abuse some cells and test them too. I guess I could build a rig with a pressure gauge on it as well. I think most cells will boil and not bust.
Has Homeland Security knocked on your door yet?
Are you going to put this up on YouTube? I would be interested in the results. I often wonder what would happen with a fet driven light and somehow there was a direct short. Iām guessing if the battery blew it would vent thru the switch which you you are holding in your hand.
All I came up with online was ppl with old surefire and mixing cells. They blew the P60 right out the bezel.
Right!
Go over and do it at your friends house.
They need not bother. If these things were that dangerous they wouldnāt allow us to have them. Iāll take this thing to the golf course and try a chip shot.
Turningbluechips, I would like to ask you a favor. Please extend your arm straight up, bend at the elbow, and give yourself a nice pat on the back for me.
And if you really want fun, take a 2-wire extension cord, strip the ends, clamp them in your dead short rig at the ends of the battery, then just as the heat is building, plug in the extension cord. Maybe you could rub some kind of oil on the underside of the battery so it will smoke a little? Route the cord where it canāt be seen & youāre on your way to YouTube Viral Heaven!
This thread sure puts me in a beer drinking mood.
Yeah! This kind of project Needs More Beer.
āHow much beer do you have?ā Not enough.
āHow much beer do you need?ā More.
āWhat kind of beer?ā Cold.
Last but not least, donāt forget the Magic Words: āHey, Bubba, watch this!ā
I thought the magic words were
Hold my beer and watch this!
Nothing should happen. With quality brand cells and a tiny bit of luck.
Quality brand unprotected cells still have PTC and CID. With an external short, when the temperature gets high the PTC is there to limit the current. Which hopefully prevents you from reaching runaway temperature.
The important part, is that youāre relying on a little luck that the last line of defense will not fail.
Some junk chinese cells do not even have PTC or CID. And the pressure vent on them is so thick that it may not work. Really it looks like a fake pressure vent to me. HKJās Disassembly of a junk chinese cell
Itās called respect. Respect for the harm that these cells are capable of, if someoneās luck runs out. Solarforce exploded (3 series cell flashlight) Sorry, but it sounds like you might think people are just being chicken.
9 times out of 10, Iām sure it will be fine. But we should still advise caution. You donāt know who you are talking to online, and you donāt know who will come by to read the post later. I often use unprotected NOS laptop pulls but still, I always advise quality seiko protected cells. Someone who uses dangerous $2 chargers from ebay or lights with no LVP (or worse, series cell lights) might be reading your post, so the most responsible thing to do is to always advise the safest option, imo. No harm in being more safe than absolutely needed.
As long as the safety is on you can spin your pistol around your finger. But that doesnāt make it a good idea.
^ Couldnāt resist!
If canāt get them to vent from a dead short then try reverse charging. They are not very fond of that.
Interesting
Do make it fit series also
Two junk cells 1 charged 1 not
And maybe some extra parts like a led and charging on the outside to simulate real life use and bad treatment more life-like then just dead shorts
That should do it.
Or how about
1 UltraFire BRC :smiling_imp: + 1 quality high amp cell in series
Looking forward to this.
But mind: Ryansoh3 really tried very hard to make a cell/flashlight go boom and he did not succeed. And beware: quality cells have internal fuses that will interfere with your attempt! And cheap fake cells may not have the amount of energy to get the desired effect.
A friend of mine has a couple ultrafire protected cells. Maybe strip the protection circuits off of them and give that a try? One charged one dead.
Trying some ultrafires would definitely be great. :partying_face:
Have you looked at your friendās ultrafires before? There is a chance that they might not even be protected. Some ultrafires say protected on the wrapper but in reality there is no protection circuit. Just a magical protection wrapper! You can usually see without removing the wrap. And if they are protected, Iād suggest trying some experiments with them before removing the protection. I suspect some of those junk protection chips are not very good. It would be great to see one blow with the protection intact.
If they are some of the worst UltraFires (like UltraFire BRC) then they might have very low capacity. Iirc some have tested to be under 500mAh. In that case, there might not be enough energy in them to reach thermal runaway from a dead short. You can put one of those very low capacity junk batteries in series with a higher capacity cell.
