New to Banggood: Astrolux® EC07 13000LM 468M Powerful EDC Flashlight 6500K+3000K+650NM Red Shooting Light Color Adjustable Tactical LED Torch With Strong 32700 Rechargeable Battery Type-C Charge and power bank function for charging your devices.
Use code Coupon Code:BG517d75 to bring the flashlight down to around $71 before shipping/tax.
Description:
The EC07 is an outdoor multi-functional flashlight that combines six light bulbs(6*HP50) in a petal-shaped arrangement, with a red beam (650nm)in the center. It features a wide floodlight design. It is compatible with two color temperatures (6500K+3000K), and the two lighting modes can be used separately (switched with a triple press of the button), satisfying various scene requirements. The brightness can reach over 13,000 lumens.
Specifications:
| Name | Astrolux® EC07 Tiny Monster Flashlight |
| Brand | Astrolux |
| Model | EC07 |
| LED | HP50(6500K+3000K)+650NM red shooting light |
| Lumen | 13,000LM |
| Intensity | 54650CD |
| Distance | 468M |
| Driver | Linear Direct Drive + Constant Current |
| Battery | 32700 Li-ion Battery (Included) |
| Two-way Charging | Type-C,and power bank function |
| Tailcap | Magnetic tailcap |
| Waterproof | IP68 |
| Weight | 212g without cells |
| Size | 117.1* 56* 40mm (Length x Head Diameter x Body Diameter) |
Features:
- 13000LM Dual Color Light Source Design
-Equipped with 6*HP50 LED, offering a combination of 6500K cool white light and 3000K warm white light, with an impressive beam intensity of 54650cd. - Features a smooth dimming mode, and a lockout mode that can be activated with 5 clicks to prevent accidental activation. - Astonishing output of up to 13000 lumens. - Provides a maximum beam distance of 468 meters.
- 650nm Red Beam Design
One Button to Lock The Target
Four-click button to open, accurately locate distant targets
Ideal for camping, hiking, hunting and emergencies.
Easy To Use & Lockout design
Come with Powerful 32700 Li-ion Cell
- Including one removeable 32700 7000mAh high-capacity power battery provides more continuous battery life
- USB Type-C Charge and Discharge
-Output support: PD3.0 PD2.0 QC3.0 QC2.0 AFC FCP SFCP PE2.0 PE1.1 -Input support: PD3.0 PD2.0 AFC FCP
IP68 Waterproof
Magnetic tailcap
Window Breaker & self-protection
Operations:
| Clicks | Off | On |
| 1 click | On(Cool White: CW LED on. | |
| Warm White: WW LED on | ||
| Cool&Warm Mix:CW&WW on) | Off | |
| Press&Hold | Turn on lowest brightness, then | |
| Smooth ramping | Smooth Ramping | |
| (lt depends on mode. Cool white: CW LED only | ||
| Warm White: WW LED only.) | ||
| Red Laser On: tum it off | ||
| 2 clicks | Strobe | Turbo(Enter CW&WW &Mix Mode) |
| 3 clicks | Mode Change (CW-WW-CW&WW) | Mode Change (CW-WW-CW&WW) |
| 4 clicks | Red Beam Light On | No Response |
| 5 clicks | Lockout: Unlock | |
| Unlock: Lockout | Lockout: Unlock | |
| Unlock: Lockout | ||
| 6 clicks | Voltage Check | Voltage Check |
Package includes:
1 x EC07 Flashlight 1 x Lanyard 2 x O-ring 1 x 32700 Battery 1 x Manual
