[̲̅=LMX=] Banggood Release: Astrolux® MF05 V2 SBT90.2 3098M Ultra Throw 7000LM Powerful Flashlight with 42000mAh 46120 Battery 2,400,000CD
https://lmxdeals.com/astrolux-mf05v2 (affiliate link)
Use code BGMF05V2 to take $80 off
Features:
  1. With SBT90.2 LED
Luminus Technology allows for large area LED chips with uniform brightness across the entire surface. These large monolithic chips generate high optical power and brightness, enabling method to replace arc and halogen lamps that traditional high - power LED arrays can’t. Using LUMINUS’s innovative technology and through MF05 V2’s improved driver circuit, the LUMINUS SBT - 90 GEN2 LED achieves extremely high optical output from a 9 mm² square emitter.
  1. 3098M, 2400000CD, 7000LM
Boasting a remarkable lumen output, it emits an ultra - bright, highly focused large beam with a reach of up to 3098 meters. This not only caters perfectly to your passion for outdoor adventures but also significantly boosts the efficiency of night - time activities, including search and rescue operations.
  1. Instant Turbo For Maximum Impact
In the on/off state, double-click the functional switch, and the MF05 V2 will respond instantly at lighting speed, illuminating the entire target area. Simple and quick operation ensures every second counts.
  1. Lockout Design & Memory Mode
1). Easily activate the lockout mode by quickly flashing five times while the flashlight is turned off, ensuring safe and secure storage.
2). 2. Enjoy the convenience of brightness memory mode, which remembers your preferred light setting for easy access every time you turn on the flashlight.
  1. 46120 Lithium Battery
Features anti-reverse connection design to prevent circuit damage from incorrect battery installation, rechargeable.
The moonlight mode can work for 84H to escort your night adventure.
  1. USB Type-C Charge and Discharge, and battery power LED indication
  2. Easy-to-Carry with Handle, Strap and Tripod Mount Screw Set.
Package included:
  • 1* MF05 V2 Flashlight
  • 1* 46120 Battery
  • 2* Tripod Mount Screw
  • 1* Tripod Mount Hanging Ring Screw
  • 1* Tripod Mount Adaptor
  • 2* The Handle Screw
  • 1* L-type Wrench
  • 2* Shoulder Strap Steel Ring
  • 1* Shoulder Strap
  • 2* O-ring
  • 1* Manual
  • 1* The Handle
  • 1* Flashlight Backpack
Thats a monster battery.
I couldn’t help but notice that while this V2 claims
  • 7000lm, 2.4Mcd,
the previous version V1 claimed a better performance of
  • 7500lm, 2.5Mcd.
Either the new version is a downgrade, or Astrolux has been lying about specs. Or both.
User djozz here tested the SBT90.2 as a bare LED, which did not hit 5500lm at 20A. To claim 7500lm, after optical losses, would be ridiculous. This certainly does not inspire much faith in the claimed battery capacity…
