[LMX] Fireflies Holiday Promotion (11th Feb to 26th Feb 2026)
Fireflies Holiday Promotion (11th Feb to 26th Feb 2026):
Galloping into the New Year of the Horse with a store-wide promotion!
  • 25% off selected flashlights! X1Q , X4Q, L60, L70. Coupon code - FFHCS25
  • 15% off storewide! Coupon code - FFHSP15
  • Buy two L50 Sol flashlights & get two free Samsung 35E 18650 batteries! Limited to one offer per customer.
  • Receive 1x free Lantern Kit with an order over $120 USD!
Spin our virtual lucky-draw wheel to win free prizes!
Our factory is taking a break for the Lunar New Year! Orders placed on February 10th onwards are expected to be processed starting February 27th 2026.
X4 Stellar Cu & NOV-Mu V2S Cu
X4 Stellar Cu
r/FireflyLite - X4 Stellar Cu & NOV-Mu V2S Cu|750xauto
r/FireflyLite - Dimmest setting|750xauto
Dimmest setting
X4 Stellar Cu
Features
  • Compact Size - 107mm x 32mm x 25.5mm
  • Weight - Full Copper 240gram ; TI-Cu 190gram
  • Quad 3535 LED Emitter Configuration
  • Battery - unprotected flat-top 21700 cells only (not included, recommended to use high-drain cells including Molicel P42, P45, P50, or Samsung 40T, 50S, or Vapcell T50)
  • RGB Auxiliary (front), Illuminated Side Switch with Charging Indicator
  • CNC Construction, All Copper (Full-Copper Variant); Copper Head and Ti64 Titanium Alloy Body and Bezel (Ti-Cu)
  • Optics - 30-deg Beaded TIR (default), 10-deg Milled & 15-deg Beaded also included
  • Open-Source Anduril2 User Interface / Firmware
  • Lume X1 40W Boost Driver, Constant Current Regulated (up to 95% efficiency) with UDR (Ultra Dynamic Range)
  • Automatic Thermal Regulation, Low Voltage Cut-off, Reverse Polarity Protection
  • Improved Be-Cu Silver-Plated Springs
  • Toughened Front Glass Lens, AR Coated (~98% transmittance)
  • 10W Fast Charging, Firefly Patented Magnetic Type-C Port (Patent 2023235776065)
  • Stronger magnetic Tail Cap (user-removable) (Patent Pending)
  • Optional Firefly detachable Lantern Kit (Patent Pending)
  • Water Resistance - IPX8
  • Drop Resistance - 2m
NOV-Mu V2S
Features
  • Compact Size - 111mm length x 32.5mm head x 26.5mm body
  • NetWeight - Full Copper 300gram ; Ti-Cu 230gram
  • 21x Nichia E21A or 9x FFL351A High CRI LED Emitter Configurations
    • Max Output: 6000 Lumens (depending on emitter choice and battery used)
  • Battery - unprotected flat-top 21700 (not included, recommended to use high-drain cells including Molicel P42, P45, P50, or Samsung 40T, 50S, or Vapcell T50)
  • RGB Auxiliary (front), Illuminated Blue Side Switch with Red Charging Indicator
  • Optimized Emitter Placement for Flood Illumination
  • Lume1 6A High Efficiency Constant-Current Buck Driver (over 90% efficiency) with FET Turbo and UDR (Ultra Dynamic Range)
  • Be-Cu Silver-Plated Springs
  • 2A Fast Charging, Firefly Patented Magnetic Type-C Port (Patent 2023235776065)
  • Removable Magnet design in Tail Cap
