Found the forum searching for a 2AA flashlight and emerged a couple of hours later having read a lot of good exchanges. I'm opting for a new thread because most of what I found on 2AA does not really apply to what I'm looking for.
Ideally, I'm looking for a 2AA that is reasonably priced (I am willing to go as high as $60 but not much more). More than cost, I'm looking for something with very good battery efficiency over power. Most of my uses are in relatively small quarters and for longer stretches of time and only rare occasion would I use the light as a flood light. Most of the time this would be for on the job (contractor) and on my tool belt, occassionaly in pocket. Ability to stand on end is a plus but I do prefer the button there so I may be willing to go without that. A good clip is nice. Lastly, a lens that can focus is a big plus.
I would appreciate any recommendations, thanks! O.
For 2AA flashlight
I would recommend Lumintop ED25.
Its have tail button and those special mode are hidden except you twist the head that i think good for daily use.
tired cycle through those special mode for certain flashlight.
floating this old thread to the top because i am once again looking for a 2AA light. i had the Lumintop and loved it. But i’ve misplaced it and need to replace it. i picked up a ThruNite and while it’s a nice light, it’s not quite right.
anything else come up in recent months that fits the 2AA mold? thanks!
Check out the Fenix E20v2. Default is low mode which helps with battery life. Uses a SST-20 but its not the best bin and its low CRI. Easy to swap, though!
If you want to get fancier, Four Sevens Quark is pretty nice. With it you can get a tall tail clicky or tail clicky with tail standing. It has the high CRI and fairly efficient Nichia 319A.
IMHO ditch the focusing beam thought. A well designed reflector will give you a wonderfully balanced beam to start with and non of the headache. Plus there aren’t very many good options outside of Coast
Assuming your requirement is still the same (ie contractor, tool belt pocket clip and tail button)
I would go with these 2 based on my experience.
Nitecore MT22A (It’s a 3 year old light with classic XP-G2)
and
Sofirn SF13 (Just because it’s a brighter light for value and I can repair it myself)
Reason why I chose MT22A
-Lightweight plastic body. Yea I know we all love a solid aluminum body but the fluorescent yellow plastic body is super visible in dark roofs and drains perfect in case I accidentally drop it somewhere
-Plastic scratches faster but doesn’t look as ugly as abused anodized aluminum.
-Thin pocket clip fits my belt easily and easy to take out (May be a pro and con because of how loosely fit the clip is)
-Has shit UI NO MEMORY that always STARTS ON HIGH but super useful for me for quick inspection because I didn’t like fumbling around lights that always start on low or some other memory I don’t know when I’m working on wires.
Reason why I chose SF13
-Very cheap n budget! I can buy several in case I lose one
-BRIGHT
-Nice and slim body great for mouth bites
-Lovely LED tint. It’s a neutral white 5700K I think. Not too warm like incans and not too surgical hospital cool white that hurts my eyes.
-NOT A DEEP CARRY POCKET CLIP which makes it easy for me to take the light out even with thick gloves.
Hope it helps. I believe others have better suggestions but here’s my take
Any reason it has to be a 2×AA light? Buy alkaleaks by the case or something?
Sofirn had the SF13, which was pretty nice, but seems discontinued. I still use mine for burning down moribund AAs.
I’ve also got a Quark 2AA-X (my first “real” flashlight) that’s similarly discontinued. Hell, I bought it (well, them, as in 2) years ago for 80bux when already discontinued, as its regular price was even higher(!). Nice. Twist head for instant-turbo, untwist slightly for all the other modes, good tailswitch, pretty rugged. That’s a good worklight.
Also got a LuxPro 2×AA light that was nice and rugged. Rubberised tube for great grip, but horrible UI (H/L/strobe, always starts on H). Runs an XP-G2 acto the spex, but seemed to me to be a G3 because of the hideous beam. Slapped on some diffusion film, and now it’s got a beautiful diffused beam that’s mostly flood.
Li cells are nice and rechargeable. Way less expensive in the long run, and you don’t have to worry about them crapping the bed inside the light and ruining it.
The S11C is a zoomie that’s not nearly as annoying or crappy as generic zoomies, takes an 18650 for hella good runtime and consistent light output, and has onboard charging, so you can just keep a cable and plug it into a lighter-adapter on the go.
I think the last time I bought the SF13, it was listed in the Clearance section of Sofirn’s site - then it disappeared across the board sometime after.
So I think it’s pretty safe to say it’s discontinued, which is a bit unfortunate since I liked it as a light to mod and lend out.
