Hi, I’ve got some XHP70’s and some 32.5mm tir lenses on the way. I’ve searched all over the place looking for suitable hosts for the 32.5mm lens but have had not much luck so far… Are there any known cheap lights that would fit the 32.5mm lens?
Can you give a link to the TIRs you bought? There are probably some hosts that would fit the diameter, but you will most likely have to add some spacers to get the height right.
The Convoy M1 has 32mm with a little sanding of the lens it should fit
