I’ve been looking for a 3x 18560 light WITHOUT a battery holder (like an SRK where the cells fit into cut-out’s in the body tube), a larger thrower head and a tail cap mounted switch.
I’m looking for something similar to the Kinfire KF-10 (tho a multi-emitter light would be ok too). My preference is for forward clickys but my main points are larger head & deep reflector for good throw and tail switch and again no battery holder.
Also is anyone aware of any lights that use a momentary (electrical) switch at the tail?
Here’s a link to my First COURUI build. Ignore the rewiring, as it was a series conversion. I’ve since built a second one leaving the cells in parallel. All you have to do is drill a hole. Make sure you have a proper drill bit so you don’t have to correct the hole, like my first one. I used a solarforce switch. I think it was $1.99 and came with adapter parts. Any switch should work.
