The thing I noticed is that my triple lights up just as far if not further than the VG 15. VG 15 is neutral white and the triple is a bit warmer. VG 15 shows haze/moisture in the air while the triple cuts through it. Neither are throwers by any means but just something to consider.
Yes the mode switching messes up when hot, the timing goes out. Much harder to reverse modes. It feels quite cheap also so that’s why I swapped all over to the VG 15.
Look at Eagle Eye X5R with XPL HI for 30 $.
Look also at candelas not only lumens.
Personaly I prefer smooth reflectors.
Also check driver efficiency. 7135 are not best one.
Finaly see what is PWM. BLF lights has twice higher frequency than Convoy.
Veritable junk. Expect a fake LED, low current, and certainly not comparable to the other lights listed in this thread. The listing may say 1200 lumens but this is false. Probably more like 4-600. You can buy a light for $6 if you wish but it will not meet your “bright” requirement. The Convoy you linked for $9.99 flash sale is probably your best bet if $10 is you limit. It will do the rated lumens. Bump that up to $20 and your options will grow.
I have this same light from FastTech (with the digital desert/sand camo) and can confirm that it’s a disappointment… Nowhere near as bright as advertised, definitely a counterfeit emitter, mine had a horrible blue tint. Also, compared to my other similarly-priced SK98 purchased to use as a host, via eBay, this light had inferior build quality. Also, the finish was disappointing, not nearly as nice as the $1.99 camo SK-68 Gearbest offered a while back.
If you want something that lights up a wide area, but not far, then Convoy S2+ with 8x7135 driver configuration is a good option for $10.
Alternatively, if you want something that lights up a narrower area but can reach very far into the distance (which can be even more impressive :laughing:, then Thorfire VG-10 is nice. You could get them for $10 from Amazon not too long ago… not sure if that deal is still on though.
Keep in mind, you will need a high quality low resistance 18650 battery that can deliver high current to take full advantage of these lights. Also, buy yourself some fire-resistant gloves so that you don’t burn yourself.
Tube lights like the Convoy S2+ and the ThorFire VG15S are probably close to what you are looking for. Both are well made, and both have received good reviews from experts here at BLF. These flashlights are often classed as "general-purpose" lights, combining good flood characteristics with a bit of throw. That is probably what you should be buying for your first powerful LED flashlight. The Astrolux S1 also falls into this category.
If you would like a bit more throw, check out the new Convoy C8 with clear anodization. At present, it is the only C8 in the Convoy product line that uses the Biscotti firmware. Biscotti has a nice variety of modes, giving you the option for whatever brightness level suit you. That means you don't have to opt for only three or four 7135 chips in order to maintain good efficiency. Go ahead and buy the C8 with eight 7135 chips. Here is a link to the BLF thread about the Convoy C8 with Biscotti.
According to this post, Biscotti will soon be available for the Convoy S2+.
The updated ThorFire C8s is also an excellent choice in the "compact thrower" category. Because it uses the Cree XM-L2 emitter, it will not throw as far as the Convoy C8, which uses the Cree XP-L HI emitter. The ThorFire C8s, however, has an excellent driver, and does not use PWM. Here is a link to the review by ReManG.
Unlike the ThorFire models, which only come in "cool white," the Astrolux and Convoy models give you a choice of tints. Here, there is no right or wrong. Tint is all about what appeals to you. The majority of BLF members, however, prefer neutral tints over cool ones. Some even find that warm tints are their favorites.
You really should spend around $20-25 for a decent light. I highly recommend the eagle x6.
GearBest also has a nitenumen ne01 for $21 the new version.
The sk98 should be looked as a host only for 5-6$ you get a $5 light.
The crelant lights GearBest has arnt bad either. Around $25
Another option might be a srk clone. They won’t be the real lumen claim maybe 2k lumens but use 4 18650 cells
If you can solder you can get the host driver and led for about $20-$25.
If you only wanna spend $10 the s2+ is the only real decent option. It may give that wow factor to people who are use to the old 2d rayovac lights. If someone has one of the new led maglites it will put it to shame especially shining out to a tree line. If you can swing $20-25 your options really open up. Walmart even sells 700-1250 lumen lights now. Lowe’s home depot do as well that run off d or 8-9aa. So if your friends have any of those you might getting the wow look yourself.
Flashlight with zoom and high brightnes - no way.
Flashlight with 1000 lumens and small head like S2+ without step down - big WOW factor. Better make good health ensurance.
Do you beleive you will see difference between 700 and 1000 lumens?
Not all the lights are zoom the mahlights are. The bushnell 1250 isn’t zoom from Walmart. Lowe’s utilitech 1000lumen not zoomie.walmart also has a ozark trail 700 lumen light one version a zoomie another version a reflector to compete with coleman lights with a decent sized reflector 6aa. my nitecore ea41 is rated 650 at high 1020 at turbo and yes you can see the increase from there to 1000 lumens. The wow would be from the size. My large reflector lights light more of a area especially downrange at those lumens then my s2 at 1200 and other 1000 lumen tubes I have. The new 3d led maglites will shine a good 250 yards zoomed in with useful light. rated at over 400 yards but you never get useful light that far. Whenever I show my lights off I usually choose a thrower something I can say hey you wanna see what’s up the street? For a flooder its a x6 triple. But most people like the throwers or a combo of both a large beam that’s goes 200-300 yards
I’ll warn you now, the S2+ is such a good bargain (low price / high quality) you’ll probably want more than one. I think I’ve bought about 10 of them now. Wife has one, kids, loaned one to a friend etc. etc.
convoy s2+ in blue with a 4c tint …usually about 13 $ at gearbest …
a s2+ convoy with a cw tint sometimes as low as 10$…gearbest …
any older BLF light that members had a hand in building …
a BLF A6 …or a blf x6 are great lights .
i still keep recommending the convoy s2 with a 5c xml from fastech for about 14$…(great tint)
Thorefire vg10 on sale for 10$ is a nice deal if you can catch one ….
lastly a brynite b153 xpl-hi for about 25$ is a nice easy to buy light …
sk98 is a light someone might like(maybe)?? ,but lots of people would say …avoid it …
