Thermal paste is something else than thermal glue. You wont use thermal glue if you can use thermal paste, as the thermal conductivity of latter is way better. But its a good compromise. I use Fujik only because that tube is huge.. but it took a month to get here.
Good question. I usually let it dry over night.. but you should let it dry under pressure. And it doesnt conduct electricity, so make sure the driver has good contact somewhere. I usually fixate the driver by compressing the pill a little bit with a pipe wrench and let some solder flow between driver and pill for electric contact.
To fill my pills with solder, I fill something with equal size (even a hole in a piece of wood works) with molten tin (I have large tin bars), file it down and sand one side flat when cold and press it into the pill. Thats where I glue the emitter. Works pretty good but it is some work.
I got this stuff because he was a usa seller, great feedback and many sold.
Now to find a couple of those rings just in case.
Thanks Nightcrawl for the grease/glue difference …… After I saw the answer, I looked it up on ebay and just about had a turkey. I guess this must be some very expensive glue! Hoo hah!
I did a quick look for edi-t lights and am not finding a lot on ebay. Some, but not a lot. Before I look at all the usual sites, what’s the most reliable cheep source for these lights? Thanks for the suggestion. I always can use a good zoomer!
That’s the stuff that increases emitter output by 1000% of it’s factory rated maximum while keeping it at subzero temperatures and reducing current draw to a tightly regulated 25mA, right?
Scary part is that the ebay ad says 14 have been sold at this price. For that price, they could have pooled their resources and bought a Honda Civic and a regular tube of glue!
If you click on “14 sold” you’ll notice that the correct price is $14.00. In fact the last one sold was on April 26 for that price, after which the listing was updated with a new Buy It Now price. It was probably just a typo.
> Round copper bar stock, turned +.001” OD,
> heated the aluminium pill (sans emitter and driver board), then
> pressed in the copper slug on my bench vice.
> Turned some iron bar stock for a completely square surface ……
Hello, China! That’s how to do it right.
Someone for sure could sell these, done right, to people like me who don’t have a lathe!
Unfinished is fine — meaning the last polishing work (lapping) can be left to the builder.
But good heat sinks in pills — someone really ought to be getting this part right.
I can (and will) get good at hand-lapping the surfaces — I’ve known how to do it and why to do it for a long time, just haven’t done it.
But I know why looking at a computer CPU and base they’re mirror-shiny-smooth — because metal to metal transfers heat, and the goop is supposed to be barely there at all, only enough to fill the microscopic gaps — that’s why they say dab a bit on and scrape it off with a credit card.
If there were a few standard-size heatsinked pills suitable for most hosts, done right, that would be smart design.
>>>>i haven’t lookied for a while, but i know dx used to carry several.
Do you mean the drivers (or the glue)? (Sorry, a lot of different subjects whirling around here.) Have you had good luck with the drivers? Did you use any with a T6? No visible PWM?
