So I’m hoping you all can help me find some material for a battery powered LED underhood work light I’m modding.
What I need is a strip of aluminum that is 36mm wide and 1-2mm thick to mount the COBs along its length. Oh, total length needs to about 24 inches (61cm). It would be OK if the total length was split into 2 or 3 pieces (for example, two pieces of 1.5mm x 36mm x 30cm stock would be just fine).
Can you think of anywhere to get some aluminum of that thickness? I don’t expect to find exactly 36mm width, so I figure I will have to cut it down (I assume).
One thing that sprung to mind was yardsticks (metersticks) from the local home improvement place, but they are too thick.
