Anywhere you guys can recommend for 8x18650 batteries? I would like minimum 3000mAh, with a good 5.0A discharge curve at maximum 5usd/pcs - is that even possible?
My led setup requires 4.9A (7 led's at 700mAh in parallel ) - does that mean that each one of the 6 batteries discharge at 4.9Ah - or do they discharge at 4.9Ah/6=817mAh each?
I'm asking because I'm not sure if I should look for batteries with a good discharge curve at 1A or at 5A?
And in the battery case description it says: Maximal continuous Discharging current 5A. Does that mean that the case will shut down if discharging current exceeds 5A?
So a total of 8 cells in parallel? For a total of 4.9 Amps distributed between ~7 emitters at 700mA each?
Your total current would be shared among parallel cells. Each cell will need to output 625mA…
Actually a fairly light load. Try finding a decent laptop battery pack and salvage your own cells for cheap!
The first post says 1p4s so you will increase voltage, current draw will be the same from each cell, if it’s 5A draw then it’s 5A from all cells, you need the 5A curve.
Thanks. But it says Maximal continuous Discharging current 5A - in the description of the battery box. I'm not sure what it means in that context. Will the protection of the box set in at 5A?
I purchased 3 of these 4S1P battery holders from Fasttech.
The protection kicks in at about 7A.
BUT: the wiring inside the holder from the negative contact to the PCB has over 50 mOhm resistance per cell! Altogether, the holder introduces almost 0.4 Ohms resistance.
At 5A continuous, these wires get really hot and even melt the plastic.
The high resistance is because these are steeel wires (spring steel), which is not a good conductor.
I replaced them with copper wires: problem solved.
Unmodified, I wouldn’t recommend them for more than 3A continuous current.
