Looking for max throw with 2*AA
Sup guys I’m looking for a 2*AA with the best throw possible given the form factor and battery restriction. Right now I have my eye on the Eagletac D25A2. I believe the XP-G2 is the way to go for the throw so I’m mainly looking for lights that use them, other than that I’m trying not to get too specific or picky I’m just looking to maximize throw with 2*AA. Any recommendations would be appreciated.
What about Nitecore EA2 ?
Equipped with an inch diameter reflector, but using an older XP-G emitter if you dont mind :open_mouth:
you may be looking for the foursevens Quark Turbo QB2A, review by selfbuilt here.
The form factor is a bit different (head is somewhat wider than body), but that is how throw is made .
If you are US based, then a Mini MagLite Pro+ probably isn’t a bad starting point. 245 lumens and plenty of throw thanks to being able to focus the hot spot.
Maglite claims 5600 lux Maglite Flashlights and Lifestyle Products
Which doesn’t seem too bad compared to some other offerings:
Most of my 2AA lights are somewhat similar in throw. My favorite is the Shiningbeam Caveman.
I've heard the Eagletac P20A2 mentioned as a throwier 2AA light.
Selfbuilts table above would suggest it is one of the poorer throwers based on lux and beam distance.
That's kind of weird, because if you compare the D25A2 and the P20A2 (both XP-G2 R5 versions), the P20A2 is rated higher lumens and has a larger head diameter:
http://www.eagletac.com/html/d25a2rc/specs.html
http://www.eagletac.com/html/p20a2/specs.html
Unfortunately they state lux for the D25A2 only for XP-G S2 version (4200), the P20A2 with XP-G2 is rated 6100 lux.
By the way, did I mention that the eagletac website is a complete mess to navigate?
Thanks for the replies everyone, I actually already own a Maglite Pro 2AA which is very similar to the Pro+ it just doesn’t have different modes and slightly lower max lumens. Its not a bad light but the beam profile is pretty ugly (donut holes and rings galore) and having to focus and adjust all the time gets annoying. I do consider it a great work like though, I use it when I need something durable that I don’t mind banging around a bit.
I’ve looked quite a bit at the Caveman, my only reservation was that a review said it used PWM on lower settings. I don’t have any experience with PWM but I was afraid it might be annoying, is it very noticeable on the Caveman?
I have not noticed any PWM with mine. Doesn’t mean you won’t but I didn’t. I don’t have it any more because it was stolen but I am going to buy several more to give away as gifts. Perfect light for non flashaholics.
I have owned several 2xAA lights. They are one of my favorite formats. The Caveman is slightly larger than some of the others but it is far and away my favorite 2xAA light. I don’t even look at other 2xAA lights anymore. Quality, fit and feel are top notch.
I have noticed the Caveman seems to be nearly identical to the Quark QB2A, so similar that I would imagine they are made in the same factory though I don’t know how to look into those things.
Not the same light at all. Although both look similar, the Quark is a XP-G2 and the Caveman is a XM-L (T5, 270 lumens $38.75 before discount) or XM-L (T6, 290 lumens $45.75 before discount).
The Quark is rated at 205 lumens.
Is the Sb Caveman throwy with an XML??
None of my 2xAA lights are particularly throwy. Inside 100 yards, they all did fine and maybe useful light out to 150 yards or so. The Caveman did slightly better than the others but not by much. It did however have better spill.
My other lights are Klarus XT 2A XP-G R5, Klarus P 2A, Quark AA2 Tactical, Jetbeam BA20, Shiningbeam Sparks and a few more that I dont remember the name and model.
The Caveman was by far my favorite followed by the Klarus XT-2A, Klarus P-2A, Jetbeam BA20 and the Quark which was my first and most expensive one but never got used after I got the others. Actually, I never use any of the others since I got the Caveman. It’s one of the lights that I just love to hold and play with. I ended up giving the Quark and one other away because I never used them.
What about a 2AA P60 host? My experience is that P60 lights throw further than the typical 2AA fare (Fenix / FourSevens).
I was just looking there seem to be a couple of P60 drop ins for AA cells but they seem to be kind of rare.
You could try building your own dropin or buy one and mod it with a boost driver, P60 Dropins are fairly easy to work with.
Yeah I did a fair bit of reading about them but it seems for AA alkaline cells its more realistic both practically and economically to just buy a pre-made light. P60s are cool but things can get a bit pricey and they ultimately don’t seem that amazing when using AA cells. Just my opinion based on very limited research so I’m sure I could be wrong.
Fenix E-21 is my most throwy 2AA
Dereelight 2xAA light-Javelin (P60 light) http://www.dereelight.com/javelin.htm
