Hello guys, I am looking for constant current led drivers. With no PWM. With modes. I read they exist but since the
listed specs of drivers are often a bit vague and PWM/no PWM is seldom explicitly stated I thought I would turn to you.
no PWM is of importance because the driver that I have now seems to create interference on the power lines that disturbs other equipment on the same circuit.
I will use 3*7135 but if I can find anything close I can modify
Beware - or, alternatively, make sure of what you actually need - most drivers that explicitly state 'no PWM' are using that as shorthand for 'this driver uses PWM but it is at a high enough frequency that it's not apparent'. I have drivers with high-freq PWM that can't be spotted by eye or by a digital camera, which can usually pick it up even when you can't see it.
Properly implemented PWM shouldn't be a problem electrically or otherwise. Ugly, notchy low frequency PWM is probably all you need to avoid.
