Looking for plug in emergency lights
We’ve been losing electric power at our house more frequently than before and the biggest issue has been the need to use flashlights at night.
Any recommendations for emergency lights that I can leave plugged into various AC outlets around the house that come on when it is dark and they sense loss of power? They don’t have to be bright (we can use flashlights if necessary) but need to last through the night.
Being able to recharge through a car’s 12V lighter port would be a plus but not necessary since only our sub division has this erratic supply problem and I can go over to a friend’s house during the day to bring them back to full charge.
P.S.: Longer term, I need to look into a transfer switch and generator solution
I think there are many different types of light bulbs or plug-in lights that will automatically come on when they sense a power outage. Doubt they would last through the night though.
These bulbs and these lights are just a few of the options available on Amz.
I’ve seen these lightblubs that have an internal battery(!) which turns it on when power’s off. Been a bunch on vipon a ways back, might still be some.
What about regular emergency lights like you see in building hallways? A bit bulky, but they’d do the job.
The Energizers have the right functionality but last about 3 hours at 40 lumens. I’d be happy to give up lumens for longer run times.
Thanks
The only emergency lights of the type in building hallways that I’ve found require them to be hardwired.
Thanks
18/2 pigtail, drill, strain-relief, crimp connectors.
I “made” a fluorescent light from a coupla extra LED replacement tubes. No fixture, the tubes work single-ended, so an extra tombstone, pigtail, and some assorted wood pieces, and I now have a plug-in standalone light. Ugly as sin, but it works.
If that is the solution, I have a handyman who would do a better job of it than me!
Perfect timing…
Just today, The Big Clive just dissected an emergency light.
And it also gets The Big Clive Seal Of Approval.
Go crazy…
Now 4 bucks!
I wish it would not take 48 hours to charge but I’m in for a few :grin:
How many blackouts do you expect to have, and how frequently? :joy:
Sorry guys but what is an emergency light.
Is it a portable light that runs off a battery?
Isn’t that called a flashlight.
If you keep a flashlight in every room, wouldn’t that work? Something with a mechanical switch that has zero parasitic drain.
These are decent for the money. At work we put 2 of these in for a nursing facility in a disused storage rooms.
No affiliation with manufacturer or retailer, no idea on longevity.
We’re in Northern California and our area has been having one every few weeks this past summer because of blown transformers or rotating load shedding on the part of the utility or them turning power out on hot days because the power lines are near dry vegetation and might cause a fire.
I’m hoping that things get better now that it has begun to cool down.
I’ve been using the term in the sense of a light that turns on automatically when the power goes off at night and provides a dim light. We do have a couple from several years ago but that only last a couple of hours.
We do keep flashlights in every nightstand drawer but it is more convenient to have some sort of dim ambient lighting.
One thought from this website is is to get flashlights with a very low brightness setting (firefly? moonlight?) and a diffuser dome and leave them on during blackouts.
These would work, especially if the night light function is bright enough to avoid stumbling over objects in the room.
They’re showing three different ones at the $20 price point and it is unclear what the differences are.
Oh ok, Home Depot has something that looks like a large night light but has a battery. When there is a power outage, they stay on.
I’ve got a few of these. I think in the short term they could be useful. The weak link seems to be the battery. Most seem to have low quality, small size, NiMh. They are continuously charged for extended periods of time, with only brief use. The end result is a light with a pretty short effective use time because of a trashed battery.
Best use is they come on with the blackout, allowing you to go around and set up your lights that have better uses, and hopefully better batteries.
I have a few solar lights with Li batteries. I’ve been surprised how well they have held up, especially given the batteries have all be mid-grade at best. They get cycled continuously, until daylight is too short to sustain them, then stored.
I imagine a properly set up one on charge might work, but not sure of the long term safety of that.
I have those cheap solar lights along our fence and some of them have held up very well while others failed relatively soon
Having two different lights, one to turn on during a failure and a different one with long run time, is an elegant solution!
