Looking for smallish EDC/Tactical single cr123a light (something like Streamlight Protac 1L but better)
Maybe you guys can point me in the right direction. I’m looking for something similar in size and operation to a Streamlight Protac 1L but with a little more power.
I need -
1. Forward clicky with monetary on.
2. Diameter should be 21.1mm or smaller
3. Single cr123a or Rcr123a
4. More than 110 lumens on high.
What are my options? I appreciate the help. I’m searching but not finding just what I want.
Thanks.
How about the Sunwayman V11R?
1) Not sure if it has momentary on/forward clicky.
2) 23mm diameter
3) CR123a, RCR134a or 16340
4) 500 lumens on Turbo.
Look at the 4/7’s as well. They are a bit pricy but good over all lights.
Jetbeam rrto
I think Sunwayman M11R is better driver by Single cr123a battery .
To give you more information, I’m going to mount it like this.
Except, I’d like something smaller and more minimalist than the light in the picture above.
The ring size of the mount is .83” (or 21.1mm). I can go a little smaller and simply shim it to fit.
The Streamlight Protac 1L is about the right size, but I feel it’s just a little underpowered with 110 lumens. While I think the 500lm may be overkill and you can actually have too many lumens (I know, blasphemy!), I’d ideally have around 200 lumens (which might mean programming the light to come on medium. That’s fine.)
The forward clicky/monetary on is important. Don’t care about strobe (ideally, it wouldn’t even have one.)
Thanks guys. I know a better light than the Streamlight is out there.
I’ve got the SWM V11R in front of me , and it is momentary.With the mag control ring , you can pre set it to the brightness you want and hit the tail switch when you want it.
Can you mod the stream light for more output?
