I would like to ask for the expert advice from fellow forum members to recommend me a few torches to consider for the purposes of wading depth illumination.
The use case:
- A flashlight is attached to the end of a alum/wooden pole and used below the surface of the water while wading in knee to waist deep water to help illuminate the water to find sand crabs. The user will be walking in the water holding the light in one hand, and a crab scoop in the other hand.
- It will be used for 1-2 hours, and should therefore have up to 2 hours runtime, minimum 1.5 hours.
- It will likely be moved around with some speed (so it will need to be water resistant to a higher depth)
- It will occasionally be stuck into the sand/mud by accident.
- Salt water use - should be easy to wash down and have no areas that will trap water —> Corrosion after use.
Features that are sought after
- Must be 1x 18650 compatible (not keen to go to 21700 etc… just want to simplify battery stocks but open to consider if its a really perfect torch).
- Maximum 2x 18650 but maybe only in a side-by-side format with a small head.
- Must be relatively light weight. Not keen on a long torch as it will be uncomfortable another handle.
- UI should be fairly simple to get to the required output. Ideally power on/off. Complex UIs are allowed but importantly, the 500 lumen mode should be easy to access for the layperson. Sometimes a programmable UI might allow for a 1 or 2 mode to be programmed, while a simple 5 mode clicky that forces you to go through strobe is bad.
- UI wise - 2 modes - a High and a decently low low would be perfect. More modes acceptable if it doesn’t make it to complicated to use. (so up to a 5 mode clicky with no strobe is ok)
- Definitely not strobe modes (unless hidden)
- Output of about 300+ lumens has been sufficient, 500 ideal, 800 even better (but starts to push the limit of battery life).
- Tint - not critical, but neutral preferred.
- Beam pattern - A throwy beam is preferred, but a balanced beam will work. Floody is probably less preferred as the water tends to be slightly murky and penetration is already limited, but this isnt a deal breaker.
- USB charging - Not needed - Unless its a hidden charging port. Waterproofing is a priority.
- Battery protection - ideal to be inbuilt, but not critical with access to protected batteries. I currently have 2600 protected cells and 3500mah unprotected. An inbuilt low battery warning/stepdown is preferred to use existing unprotected cells.
- 1” body design to be compatible with mounting hardware (not too important but nice to have).
- Waterproofness is important (of course) and should not be compromised by mode changes/turning on the light. Waterproofing must be foolproof - no flimsy usb port covers.
- Price - Anywhere from $30-150 is acceptable. Want a minimum build quality to ensure waterproofness.
- A budget option is great as it will allow for rough use without guilt.
- A more expensive option that does the job better is also allowed but as a torch that will dig into mud it can hurt a bit to scratch it up.
Current torches being used
- Armytek G109.2 - is older but has double o-rings, about 400 lumens and 2+ hours battery life. about the $100 mark. Great torch but not available anymore in that model.
- Lumintop P16X (i think). 2 mode. A mid priced torch with low range features, has about 800 lumens on high, but due to the un-regulated driver, drops down over time as the battery drains. Kinda works, but nothing fancy or regulated. Low mode is a resistor in series when you unscrew the tailcap halfway! Seriously low tech solution for low mode and relies on a resistor to drop the voltage to the unregulated driver!!
Torches being considered
- Current Armytek Predator Pro V3- Pretty sturdy option at the mid to higher end of the price range. Problem is that the preferred 500 lumen mode to get 2 hours runtime requires the head to be loose which may compromise the waterproof seal.
- Armytek Doberman Pro - pretty much the same as above, just a more compact head for a slightly less throwy beam. Same problem with the loose head on the High mode.
- Another P16X - but its kind of a meh torch, won’t get any daily use due to the very basic feature set.
- Would love to hear what other people can find which might do the job.
I have been looking for something that suits this, but not finding many ‘perfect’ fits for the specification.
Many dive torches are 21700, which is ok, but their design isn’t particularly clean for the price.
I wouldn’t mind a budget torch, but would like someone to vouch for its waterproofness. I don’t mind a budget model but I don’t have much up-to date experience with recent models. In the past I have bought budget ones that have inaccurate construction tolerances that render o-ring seals weak or useless, or there is no o-ring/gasket at the lens end of the head. Makes me a bit weary for this underwater application.
Thanks in advance!!!
