White Light Menu - low mode only
Changing this will also adjust the brightness of the side light low and RGB. Reducing the output lower than two steps below the default will result in the low level flickering.
• Rotate switch to side light
• Unscrew tailcap
• Tighten the tailcap whilst holding the switch until the side light flashes 3x amber colour
• Rotate switch to white light mode
• 1x press to start, shows 3x red flashes
• Each press increases/decreases brightness
• 3x press changes direction (3x blue flashes = decrease / 3x red = increase)
• 2x press saves output, 3x amber flashes
• 2x press exit, 3x cyan flashes + 1x slow
Laser Class 1 & 3R Menu
• Rotate switch to laser
• Unscrew tailcap
• Tighten the tailcap whilst holding the switch. 3x red flashes shows class 3R, 3x green shows class 1 enabled.
• 1x press changes between class 1 & class 3R
• 2x & 3x press saves and exits with 3x cyan flashes + 1x slow
Note: If the lower power group is selected in the Laser Group Menu, 3x green flashes disables the high level.
Mine was a class 1 unit, but it may have been configured at the factory in the lower power group, so I had to first switch groups to unlock the 3R laser output.
Laser Group Menu
• Unscrew tailcap
• Rotate switch to the laser mode
• 1x press to start, shows 3x amber flashes
• 4x press changes between groups (1 - 3R group = green flashes / lower power group = cyan flashes)
• Hold cycles between two levels in each group
• 2x press saves the selected group, 3x amber flashes
• 2x press exits, 3x cyan flashes + 1x slow
Note: After the 4x press step, a 3x press results in 3x blue flashes, not sure what that indicates.
Starting on the side light and switching to the UV, 3x green flashes, 1x press flashes magenta with regular strobe following.
There’s 4 accessible laser brightness levels excluding moonlight.
Factory Setting
• Class 1 = Single Level
• Class 3R = Class 1 & Class 3R available to cycle between.
Then a separate lower power group.
