Low amp? :(
Hi All
I’ve been trying to do some ‘testing’ and have been taking tailcap readings of some of my different lights…
The long and the short… they all seem ‘low’.
I just got a shipment in from FT with a 2800mA Nanjg… I put a p60 drop-in with an XP-G2 emitter. It is brighter than all my other lights but my tailcap reading reads ~1.4A with a 18650 and ~0.8A with a 16340.
I am assuming these are quite low considering it is a 8*AMC7135.
On my BLF Mini02 I get a reading of ~1.4 as well.
Could it be my MM? Or is there something else I need to upgrade in the light to get the amps up?
Do I have to upgrade the tail clicky? Or, are the advertised amps of the drivers similar to Chinese lumens…?
Thanks for any clarification and direction… much appreciated!
Have a look here for some tips on taking tailcap readings.
Cheers
No offense but my mini 02, while I haven’t preformed a draw test on it yet, is definitely pulling more than 1.4amps since that drive current doesn’t trigger the protection circuit on my TF flames as I have other 1.4a lights that work fine at it.
Like wise I have a 2800millamp driver and it’s pulling like 2.45-.68 amps on my p60 on average (Cell charge rate, composition, circuitry, etc); however I fried it and it’s probably not getting the best contact; I still need a new centering disk and to wrap the drop in.
You could be making a mistake (Not pressing the probes on properly so the readings wrong) or it could be faulty equipment (Multimeter, test leads or even weak batteries). Ultimately I can’t really tell you but it’s unlikely all your lights are reading that low.
thanks! I’ll take a closer look at my MM (still learning how to use it )
:slight_smile:
no offense taken! :slight_smile:
i’m just trying to figure out if my MM is well calibrated (or most likely not)… I am ‘ok’ with ‘unlikely all your lights are reading that low’… :slight_smile: I just don’t want all my lights to actually be that low… lol!
