No, M1 kit was designed special for Khatod quad. Other optics (carclo quad) is smaller height, smaller OD, so spacer should be higher, liner ring thicker and etc.
P.S. Im using M1 with S2+ spacer and 30mm Carclo single optics.
Guys, I already have almost hundred hosts, I can not have all mks of all models of all brands. I dont see enought feedback from members, if anybody wanted to have suitable spacer for other brand C8, he could help me with internal dimensions when I asked you.
Convoy mk3 is target host. Should also fit mk2. It defenetly wont fit host with pcb place smaller than 20-21mm. C8 reflector outside shape is much smaller than C8 head so there is some free space inside and manufactures can make head thinner or thicker as they wish.
I will send you one from the first test samples, you will be able to test compatibility with different hosts.
I was merely curious, I prefer the convoy host myself as well, I just have a few off-brand C8’s laying around that I have not been able to figure out what to do with. I was thinking I could possibly build some triples out of them if it fit. No big deal if not.
I will say that I can swap the convoy reflector into the other C8 hosts without much trouble.
If you want to send me a prototype, well I never turn down free stuff :partying_face:, although I do not have any of the optics and it doesn’t look like you have them in stock. I do have 3 C8 different lights IIRC.
I hope to have the money to order some X6 spacers from you next month, if they are done at that point I can possibly make my order then and you can add the C8 spacer to it.
