Everything arrived safely in two weeks and the packaging is phenomenal. Can’t wait to build my flashlights.
I am very happy to read that !
Robert
First post updated, lots of items on sale.
As expected, I need to reduce the range of goods, hope for your undestanding.
Hi Kiriba-ru.
Received 2 aluminum X6 and 1 copper X7 spacers. As usual, nicelly machined products and well packaged.
My EE X7 already is a xp-g3 triple and working flawlessly.
Next step, build the X6 triples.
Thanks Kiriba-ru.
S2+ copper pill for triple received, in good condition.
Thanks Kiriba.
Received my spacers with expert packaging in about 30 days to California, thank you!
Recieved my parts. Everything came very well packed in little re-useable cases that were heat shrunk closed. Parts look very nice. Will likely be ordering more in the future.
Package arrived! And the shrink wrap was done incredibly well. Arrived flawlessly.
How about a copper spacer for a Convoy M1/MTN Electronics quad? Seems like it would be popular.
Some time ago Ive decided that M2 can fit 24mm Carclo while M1 should fit 25.4mm Khatod.
Received my package yesterday, very well packaged and it arrived pretty quick considering the distance it had to travel, 2.5 weeks to Macedonia.
I have a noobish question about modding with the c8 tripple spacer though…
I will be using the Noctigon XP32, so to get my wires through do i just drill the middle of the mcpcb?
If so , is there any chance of screwing things, and what precautions i should take?
Yes, you need to mark and drill 3.5-4.0mm central hole both in pcb and host.
As with other mods with central wire holes, I recommend to put driver, solder wires but not screw down driver retaining ring before you assemble top of your build. You should put down optics, ring, screw down bezel, and only after that screw driver ring with force. This allows spacer and other parts rotate in host while screwing bezel, and wires wont be broken because they will transfer this screwing movement down to the driver which will also rotate.
Great , thanks for the advice.
Off to do some drilling
Need some advice about S2+ retaining rings.
How big should be ring internal diameter to fit most 2-side drivers?
Some 7135×8 drivers need up to 15.5-16mm internal diameter of the retaining ring .
Also, I should say that traveling distance doesnt matter. Average shipping time to the US is two weeks while Germany or Spain can easily take 4 weeks or more. Since post services are using air transport, delivery time mostly depends from quantity and quality of sorting centers that parcel should pass trough.
I see , all clear on the shipping, will have that in mind.
Assembled the C8, and i must say its a looker. The pattern of the ledil optics combined with the gitd oring(nice touch btw) makes it look pretty cool in my eyes.
Got around 8A on triple G2’s with only tailspring bypass.Wont brake any records, but i consider it good enough
Looks even better in person
I’m just waiting on some parts from Richard at MTN and I will be building up a bunch of new multi-emitter lights.
Got around 8A on triple G2’s with only tailspring bypass.Wont brake any records, but i consider it good enough Smile
For more throw, try polishing (courtesy DB Custom): New light, DBC-03 FINISHED! 6-2-16 - #34 by Brett_H
