Hello, my first post on here. I’ve seen a few posts about red flashlights but wanted to get some feedback on what I’m considering and any other suggestions.
I’m looking for a flashlight that will primarily be used in a low power red mode. I’d like to predominantly use it to be able to check on the kids when they are sleeping/going to sleep without tripping over toys and other bedroom hazards. Secondarily, I would also use it for the occasional camping trip. I want the light to be red as soon as I turn it on, without having to go through multiple clicks or starting out with white.
“Must haves”: low powered and red capable, either by filter or dedicated red LED, be able to turn it on in low powered mode in red. I don’t want to have turn it on at a high setting or in white and then switch to red and/or low powered. This unfortunately rules out the Fenix LD15R, even though I like the right angle form factor, as I understand it, it only remembers the white settings and I’d have to start in white then switch to red each time.
Strong preference for a rechargeable unit.
Slight Preference for an 18650 battery.
I’ve been looking at a few options. The first being the Fenix PD35 V3.0 Flashlight with the red filter adapter.
Although this one is kinda spendy, it seems very high quality and comes with a rechargeable battery. I like that this would remember if I keep it in ECO mode (5 lumens) and at that setting it has a listed duration of 230 hours. So even though using a filter isn’t as efficient, that is still plenty of time, and as a bonus, I could take the cap off to use it as a white light, although I don’t see using it this way very often. I also like that unless I accidentally bump the secondary switch, it would stay in low-powered mode (and stay red as long as the filter is on).
I’m also looking at the EMISAR D4V2 with SST-20 deep red LED.
I like that it is a dedicated red led light, which all else equal I understand would be more efficient than a white light with red filter. The downside is it would be a little less flexible, but again, I mainly plan to use it in red light mode so this doesn’t really matter. This one seems highly programmable, and reading through the manual, it appears as though I could set this to start in a low-power mode “floor” and it would remember that, but would like confirmation. It is also a little bit less expensive, but with this one, I would need to buy a battery and charger separately, so it might not be much less expensive.
I’ve also looked at the JAXMAN E2L with red led. This one doesn’t seem as programmable (or programmable at all?), which in itself doesn’t matter as long as I can turn it on in low power mode and it stays that way the next time I turn it on. The price is lower, although I would still need to buy a rechargeable battery and charger. Right or wrong, my perception is that the quality of this one is lower.
I would rather spend more and buy a high quality item that will last a long time.
Any thoughts on these options or suggestions for other options for a low-powered capable red flashlight.
